| Chip Amps Amplifiers based on integrated circuits |
hiii
i m building a LM1875 + PGA2311 with 3 input relay selection- confused for how to do hte pcb for 1875 , i have made a few layout could the gurus out here help me with it, hmmm only one thing is that i dont have schematics, all the designs are on datasheet diagrams also for the pga2311, also if icould make one single pcb for 3 relays + PGA2311 + 1875 (2) than that would be just perfect , a small single sided 6"X4" or maby be a litter smaller so could probably do away will maximmum of the wiring currently i just have pga2311 and relays on one board |
#2 |
Search Thread = lm1875 pcb layout for gainclone.
#3 |
how is this layout ... , Today got my samples from N.S.C. |
#4 |
this one looks good, make a PCB yourself by toner transfer method.
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout |
#5 | |
hey thanks i was scared as to was it ok or good or bad or useless i m going to do a toner transfer only,,, i m confused for should i keep the PGA2311 with 3 relay and that RCA connector on the amplifier board or just connect the thing via wire to the amp input, |
| LM1875 for headphone amp | maurycy | Chip Amps | 9 | 8th February 2010 04:34 PM |
| Building minimal PSU for LM1875 gainclone | Pato666 | Power Supplies | 0 | 19th November 2009 02:03 AM |
| what is the suitable loudspeaker for my LM1875 amp??? | thomgun_lc | Multi-Way | 0 | 2nd May 2005 08:12 AM |
| LM1875 amp not working | TheBat | Chip Amps | 7 | 28th July 2004 01:16 AM |
| Building LM1875 GC | JhonDoe | Chip Amps | 5 | 9th February 2004 02:20 AM |
| Page generated in 0.07345 seconds (72.37% PHP - 27.63% MySQL) with 11 queries |
