Old 3rd March 2010, 03:18 PM   #1
Default how to use Sanyo chip amps?
I didn't find any threads on this specifically, so I am throwing this question out there...
There are lots and lots of Sanyo STK chips out there with a wide range of power levels. Mostly they need to be used with 8 ohm impedances, and don't have top notch performance, but all in all they are not bad and seem to be pretty straightforward to implement.
So the question is, how does one create an amp: have a custom PC board made or try to wire point to point, use perf board, etc?
Can anyone speak about their experiences using the STK chips?
-Charlie
Old 3rd March 2010, 03:42 PM   #2
wazzy is offline wazzy  Zimbabwe
Default stk
Greetings, I have used a few of these before, actually my first 'chipamp' was a stk4141, I used the pcb design in the data sheet and it worked okay. check out the link for datasheets for various ic's
Old 3rd March 2010, 07:41 PM   #3
Hi Charlie
For initial testing, I use perf boards.
Below are 2 STK chips I tested. One is a STK4050V (200W/8 ohms) and the other a STK442-130, a 2-channel, 150W/6 ohms power ic.
Mike
AmpsLab.com
Chip amps vs class D amps lanchile Chip Amps 46 21st April 2010 04:38 AM
Boat Amp! Sanyo LA4508 8.5w chip oublie Chip Amps 6 28th June 2009 05:47 PM
Clarion car stereo problem - bad Sanyo LA4743B chip? GirchyGirchy Chip Amps 4 22nd August 2005 06:41 AM
Has anyone compared the Chip amps against Class T amps? soongsc Chip Amps 3 24th July 2005 11:50 AM
Help needed with old Sanyo STK chip amp please georgehifi Chip Amps 3 3rd September 2004 09:14 AM
Page generated in 0.07706 seconds (73.53% PHP - 26.47% MySQL) with 11 queries
