Old 3rd March 2010, 02:11 PM   #1
Default Can anybody check this LM3886 PCB
Hello friends. This is my first pcb design. can you check this pcb.
Old 3rd March 2010, 03:54 PM   #2
A schematic would be helpful.
Tyler
Old 3rd March 2010, 03:59 PM   #3
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh Send a message via Skype™ to kuldeepsingh
nice attempt. good grounding layout and separation of input and output. Have you made power supply PCB?
My Best LM3886 PCB layout
Old 3rd March 2010, 04:16 PM   #4
ratza is offline ratza  Romania
ratza's Avatar
Pretty nice. Move the 100nF decoupling caps closer to the LM pins. Why do people use input capacitors that big? Use smaller ones. You won't believe it, but the quality of the capacitors on the negative feedback influence the sound quality as well.
Any solution is a compromise.
Old 3rd March 2010, 09:00 PM   #5
I used the schematic in LM4780 datasheet (Auxiliary Amplifier Application Circuit).
I have WIMA 1uF/400V caps therefore the input capacitor is so big =).
thanks for your comments and advices
Old 3rd March 2010, 10:03 PM   #6
tomchr is offline tomchr  United States
tomchr's Avatar
You probably don't want your supply caps overlapping with the supply connector/terminal block. Also, I suggest leaving more room (50-100 mils) between the input connector and the large cap. Furthermore, your 2200uF caps are probably rather tall, thus, they will interfere with the mounting of the LM3886. If you have the parts already, I suggest placing the parts on a print-out of the layout and verifying that you can get to the mounting screw of the LM3886 with a screwdriver with the supply caps in place. And as others have said already, the 100 nF decoupling caps should be right at the pins of the LM3886 for them to be the most effective.
Otherwise, it looks pretty good -- assuming the layout matches the schematic that is.
~Tom
Old 4th March 2010, 11:20 AM   #7
Roushon is offline Roushon  India
I think the negative track behind the LM3886 should be avoided as
you will not be able to fit the heat sink so that some part of it
goes below the IC (that is below the PCB). I mean the PCB should end just
before the back of LM3886. Also as already mentioned, decoupling caps
be as close to LM3886 as possible and the input (including the input cap) should
be away from the filter caps and the negative track.
I just built a big project around LM3886, so these are my first hand
experience. High power amp like LM3886 will amplify a very slight
distortion in the input to a very large audible one.
I hope my limited knowledge helps in some way or the other.
Roushon.
S. Roushon
Please Check this LM3886 Schematic mymindinside Chip Amps 28 21st August 2007 09:23 PM
PCB Check Khron Chip Amps 48 28th May 2006 09:55 PM
Please check this LM3886 layout for me CJ900RR Chip Amps 7 26th February 2006 08:35 PM
Page generated in 0.07913 seconds (75.55% PHP - 24.45% MySQL) with 11 queries
