Old 2nd March 2010, 12:42 AM   #1
Default Any chip?
Hi guys,
Can you suggest me an internal bridged, stereo power amplifier chip, up to 40W and work with at least 40V power supply?
Old 2nd March 2010, 08:50 AM   #2
40 W into which load and at which THD? 40 V single supply? That would already give you 37 W into 4 Ohm from an LM3886 without bridging. If you want 40 W into 8 Ohm, it takes much less than 40 V for a bridged amp, e. g. AN7194 needs a 24 V single supply for that.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 2nd March 2010, 03:54 PM   #3
No, I was talking about dual supply, +/-20 = 40V.
The load is a 8 ohms speaker.
Any ready chip?
Old 2nd March 2010, 10:38 PM   #4
you wont get 40 watts out of +/-20 volts into 8 ohms unless you use a bridged amp as pacificblue mentioned.
You need at least +/- 30 volt rails to get 40 watts.
A dual supply +/- 20 is still a 40 volt supply.
Old 3rd March 2010, 01:08 AM   #5
tomchr is offline tomchr  United States
tomchr's Avatar
How about two bridged LM3886's? Four resistors, two caps, and a few other sundry items (decoupling caps, etc.) and you're done.
I think there is a dual-channel LM3886-ish chip out there also, though I forget the part number. LM4720? I forget. Bridge the two channels... Look in the Overture series by National Semiconductor.
~Tom
Old 3rd March 2010, 06:41 PM   #6
Originally Posted by soundbabe View Post
up to 40W
..means you want 40 W or less. You can get that from a single LM3886 with ~±29 V rails or from bridged LM3886/LM4780 with ~±15 V rails. You can also get that from a single LM3875 with ~±30 V or from bridged LM3875 with ±17V.
..means you want a power supply of ±20 V or more. ±20 V with bridged LM3886/LM4780 will give you ~70 W into 8 Ohm. With bridged LM3875 you get ~60 W into 8 Ohm.
What is more important for you? Less than 40 W or more than ±20V?
Which Chip Better thomasfw Chip Amps 6 18th April 2005 09:03 AM
What chip should I use? soundNERD Chip Amps 5 30th September 2004 03:57 AM
Is there a chip that can... soundNERD Chip Amps 10 16th November 2003 01:18 PM
Chip carlmart Solid State 7 25th June 2003 01:38 PM
Page generated in 0.07608 seconds (71.69% PHP - 28.31% MySQL) with 10 queries
