| Chip Amps Amplifiers based on integrated circuits |
Hello Guys,
I am A newbie Here, I have bought four LM3875T Power amplifiers. My question As a newbie in the amplifiers arena is: 1: Can I simply use 2 of the said chips to make a setero amplifier? 2: is there any circuit/schematic to direct me how to do so? 3: Is this a COMMON method, or I have to use a setero power amplifier chip?, What method is better? 4: Can I use a single heatsink for bothe said chips when I build a stereo amplifier out of them? Thanks in advance. |
#2 |
1. Stereo? Um, yes, of course.
2. You take your basic stereo cable. Left (white) goes to input of one chip, right (red) goes to the input of the other. Ground (black or simply bare copper wire) goes to ground of both chips. 3. Yes it's a common method to use 2 mono amps to make a stereo amp, because in effect a stereo amp is two mono amps, and a 5.1 amp is 6 mono amps. 4. With identical chips, you can use both the same heatsink and the same power supply. |
#3 | |
http://www.audiosector.com/nigc_kit-users_guide.pdf |
#4 |
The much easier way is to follow one of the projects at Decibel Dungeon
here Gainclone chip amp index page |
#5 | |
Is there any link to direct me to the bisics of a stereo amplofier, Or any link to a schematic of using any mono spreate chips to create a stereo Amplifier? What did you mean by "and a 5.1 amp is 6 mono amps."? About the problem noumber 4, Do I need to insulte both chips in a single heatsink? I have worked with TDA1557 as a stereo chip, but I felt the both channels affect each other by having the a weak left output to the right channel and vice versa? |
#6 | |
#7 | |
#8 |
Can you guys please let me know the MAX og gain I can get out of LM3875T at 100kHz? I mean If I want the chip to work at 70kHz to 100KHz then what gain I must expect, yet allowing the chip to work in a liner state?
#9 |
Maximum open loop gain at 100kHz is around 37dB.
Any solution is a compromise. |
#10 |
have you downloaded the National datasheet for that chipamp? and overture design guide (excel spreadsheet) and AN 898 and AN 1849
regards Andrew T. Last edited by AndrewT; 2nd March 2010 at 09:13 AM. |
| National LM3875T for sale. | Hisatugo | Swap Meet | 5 | 24th October 2009 12:27 AM |
| 2 x LM3875T on the same heatsink ?! | thoronx | Chip Amps | 9 | 23rd June 2008 09:41 AM |
| LM3875T to be obsoleted | jackinnj | Chip Amps | 12 | 27th June 2007 08:20 PM |
| lm3875t? or lm3875tf | karma | Chip Amps | 36 | 25th May 2004 07:03 AM |
| Sound Quality of LM3875T | cwteoh | Chip Amps | 29 | 8th May 2004 01:19 AM |
| Page generated in 0.10444 seconds (78.90% PHP - 21.10% MySQL) with 10 queries |
