| Chip Amps Amplifiers based on integrated circuits |
I've just started building a Gainclone amp. Currently I am just experimenting with a single chip (mono) trying to get my head around ground loops etc. but my LM3875 chip is getting really warm.
I am using a 240v - 2 x 18V Toroid, and currently using a bar of aluminium 90mm x 30mm x 10mm. I eventually want to make my own enclosures for my amps, and was originally going to just bolt the chips to the case, but maybe just plain old aluminium won't be good enough. Would this be any good: FISCHER ELEKTRONIK|SK 100/100 SA|HEAT SINK, 100MM, 1.5°C/W | Farnell United Kingdom It says : Thermal Resistance:1.5°C/W and the calculation I did on the Overture Design Guide said for a 6 ohm load that I need 3.08C/W. I don't understand C/W, so do I go lower or higher to be on the same side. Or maybe this one: http://uk.farnell.com/fischer-elektr...66?Ntt=4621566 This would make my case look better ![]() Thanks
Another project of mine: (a very big one at that!) http://www.mp3car.com/vbulletin/show...5-pimping.html Last edited by portreathbeach; 27th February 2010 at 11:32 PM. |
#2 |
As long as the heat sink has equal or lower C/W number than what you need you are OK.
A heat sink with 1.5C/W will heat up half of what a heat sink with 3C/W will. space |
#3 |
Thanks very much for your info
Another project of mine: (a very big one at that!) http://www.mp3car.com/vbulletin/show...5-pimping.html |
#4 |
These would work. However Farnell do a nice 160 wide, 40mm deep, 75mm long heatsink on there by Fischer, and this will adequately cool two LM3886's (i saw your other thread) perfectly
#5 | |
For this the 1.5C/W would be ideal. If you want to mount two chipamps on the same heatsink then adopt 0.7 to 0.8C/W
regards Andrew T. |
#6 |
Thanks for the advice,
I was a bit confused with the sizing of heat sinks, but at least now I know. I will obviously way oversize it, just to keep the chips cool.
| Advise on heat sink | pmchoong | Pass Labs | 13 | 13th August 2011 05:50 PM |
| my heat sink picture | space2000 | Solid State | 37 | 20th July 2008 08:59 AM |
| Heat Sink Question | darth_audio | Car Audio | 2 | 14th October 2005 04:47 PM |
| Heat sink schematics | Llafriel | Pass Labs | 10 | 18th June 2004 07:05 AM |
| How much heat sink is necessary? | rosss | Pass Labs | 11 | 23rd February 2003 05:23 AM |
| Page generated in 0.08673 seconds (73.81% PHP - 26.19% MySQL) with 10 queries |
