TDA7294 Stereo/Bridge with PSU - Page 12 - diyAudio
Old 27th February 2012, 11:19 PM   #111
Originally Posted by rahultvm View Post
Sir, I had build TDA7294 bridge amp(subwoofer), working is good! volume is great!
but,I have problem, very poor bass effect!,punching bass effect is very poor!
I also connect and check tda 2030 x 2 amp... bass of tda 2030 is great! but less o/p power
how to rectifier my problem sir?(how to increase deep bass in tda7294?)
I think, lm3886 is good,
but,lm3886 is very costly in india
tda7294 is very cheap in indian market
please help me sir
I will wait for your reply
you change as picture. Bass is good, medium is low, treble is good
Old 13th March 2012, 10:19 PM   #112
barila is offline barila  Croatia
can someone please post an Electronic Circuit of stereo version of this amplifier ??????
Old 8th April 2012, 01:57 PM   #113
Originally Posted by apexaudio View Post
Wire jumper for right channel rail are on the cooper side of pcb, 22k (dash) and smal jumper is only for bridge mode, not connect for stereo.
then why you didn't remove small jumpers from stereo scheme??????
Old 8th April 2012, 04:59 PM   #114
apexaudio's Avatar
I did remove it, see post #55
Old 16th April 2012, 12:03 AM   #115
Send a message via MSN to nanodocl
Default tda7294 in bridge config
Hi, How can I get 400W (200W per channel) with TDA7294? As I understand, only 7293 allows parallel conection to add more power to the output, how you do it with this one?.
Old 10th August 2012, 03:02 PM   #116
Maroof is offline Maroof  Pakistan
Can I use TDA7293 in place of TDA7294 ? Because I have a 35-0-35 ac transformer which is = +/- 49v dc . maximum voltage for TDA7294 is +/-40v.
Old 10th August 2012, 05:04 PM   #117
Your 35-0-35Vac transformer may give out as high as +-52Vdc.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th August 2012, 07:29 PM   #118
Thanks for correcting me . Is there any chance to operate TDA7293 with +/- 52vdc?
Old 11th August 2012, 09:46 AM   #119
the spec says +-50Vdc max.
regards Andrew T.
Old 22nd September 2012, 01:19 PM   #120
joeyt is offline joeyt  Philippines
sir apex do you have back side pcb of post no.58?
tnx,
joeyt
Bridge Mono a stereo amplifier with balanced outputs gni Solid State 1 16th April 2009 03:44 PM
Dual Bridge Rectifiers in PSU - why? monarodan Pass Labs 9 9th January 2007 03:36 PM
One bridge ok for stereo UCD400 amp? Foxx510 Class D 0 30th November 2006 03:02 AM
One or two bridge PSU alexan Parts 9 20th November 2006 05:37 PM
Bridge rectifiers in PSU Speek Solid State 6 16th August 2002 08:50 AM
Copyright 1999-2017 diyAudio
