LM3886 Schematics + PCB
Old 9th June 2012, 04:11 AM   #81
charlestpt is offline charlestpt  India
Hey Apex audio
can i use this gain clone to run this type of speakers at home?
what is the sensitivity of input?
how much input signal voltage required to get full power output?
JBL GT6-S266
Old 9th June 2012, 12:22 PM   #82
R.I.P.
Ch,
there are no sensitivity nor impedance data in that link.
What is the speaker impedance?
What is the speaker sensitivity?
regards Andrew T.
Old 9th June 2012, 01:53 PM   #83
Originally Posted by AndrewT View Post
Ch,
Hi! Andrew
You have to scroll down to see the specifications of the speaker
Old 9th June 2012, 01:56 PM   #84
R.I.P.
93dB means nothing to me.
4ohms tells me it is not really suitable for chipamp power. Not enough current capability from chipamps.
regards Andrew T.
Old 9th June 2012, 02:01 PM   #85
Hi Andrew
93dB does not sufficient for home listening?? Then tell me how much SPL should be required for home listening
and LM3886 doesn't support 4ohms load??
Old 9th June 2012, 02:05 PM   #86
R.I.P.
93dB means nothing.
That is not a specification, that is a ratio, nothing more.
Look up chipamp current capability.
You will find that all are current crippled. They can drive >=4r0 resistive test loads. They have insufficient current capability to meet the demand of a real 4ohms speaker.
regards Andrew T.
Old 9th June 2012, 02:35 PM   #87
93dB means nothing.
How much will you prefer
Old 9th June 2012, 06:39 PM   #88
No 4 is offline No 4  United States
This is disappointing to say the least, I am in the process of collecting parts for a lm3886 based amplifier that is going to be used with 4ohm speakers
Old 9th June 2012, 06:54 PM   #89
RogerGustavsson is offline RogerGustavsson  Sweden
Most speaker manufactors show very optimistic technical data. As this a car speaker, the 93 dB can relate to a distance of 0.5 meter. Nominal impedance is 4 ohm, 2.83 V is than 2 W.
A chipamp based on LM 3886 can drive a 4 ohm load. I could be adviceable to use a slightly lower supply voltage.
Old 9th June 2012, 07:40 PM   #90
I used a 22v transformer for my lm4780 build as recommended with the intention of using it with a 6ohm pair of speakers and a 4ohm pair. It seems to me Andrew is saying that these chips cannot be used with 4ohm speakers no matter what amount of voltage is applied.
P.s. I am listening to my lm4780 with 4ohm klipsch kg4s right now and it sounds delightful. Some more discussion or explanation of this topic would be appreciated.
LM3886 Schematics + PCBHide this!Advertise here!
Lm3886 pcb livenicely Chip Amps 33 20th December 2013 10:36 AM
Non inverted, 3 x parallel LM3886 schematics and layout. markiemrboo Chip Amps 0 6th December 2007 12:42 PM
Need schematics and board files for parellel lm3886 clipto333 Chip Amps 5 5th April 2007 04:31 PM
