LM3886 Schematics + PCB
Old 5th May 2010, 03:10 PM   #31
Ar4 is offline Ar4  Latvia
Have you made any simple PCB for LM4780 too?
Old 5th May 2010, 04:43 PM   #32
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
No, but you can find circuit here:
LM4780
Old 5th May 2010, 06:30 PM   #33
Thanks for that apexaudio
Old 5th May 2010, 11:42 PM   #34
erikyuki is offline erikyuki  Brazil
Send a message via MSN to erikyuki
Originally Posted by apexaudio View Post
Do you builded some gainclones?
Hi, apexaudio!
Yes, I did build a gainclone, and thanks to your help i can say it works well!
I did, though, use a TDA7377 chip instead of the 3886, because I got this chip for free from a friend. I decided to do so because I wanted to gain some experience before spending a larger amount of money on a project.
Not that the 3886 project is expensive; on the contrary, everybody says it is quite an affordable way to build a nice sounding amp. I just happened to have almost everything I needed (except for the box and heatsink) to build an amp with the 7377. Since it uses a single 12V power supply (which I already had), I decided to build the amp with this chip, on a breadboard. I must admit this is not the best solution, but as an experiment, it is acceptable.
Now that I've built my first amp, I'll start planning the one with a 3886 with a lot more care... and I'll try not to repeat some mistakes I made on the first one!
Unfortunately, I haven't got a decent camera to share a picture yet. As soon as I get one, I'll surely post some pics here.
Once again, thanks a lot!
Cheers!
Erik
Old 7th May 2010, 08:43 AM   #35
apexaudio's Avatar
Originally Posted by erikyuki View Post
Hi, apexaudio!
Cheers!
Erik
I think you have no mistakes with second amplifiers, gainclones are very simple.
Old 14th July 2010, 10:15 AM   #36
Tube Pro is offline Tube Pro  Macao
Tube Pro's Avatar
Default PCB design
Very small PCB based on Yorkville Amps.
Hello Mile,
Can you share a PCB design of this LM3886 as an inverting amplifier?
(Pin # 9 as the input, instead of pin # 10)
Thanks In Advance.
Joel
Old 16th July 2010, 06:18 AM   #37
apexaudio's Avatar
Originally Posted by Tube Pro View Post
Hello Mile,
Thanks In Advance.
Joel
I have not pcb design for inverting amplifier.
Old 14th February 2011, 03:30 AM   #38
Hosam is offline Hosam  Syria
Mile as you mention this amp could be successful sub amp so I just need to know what I should do to get best quality for sub with this PCB if you have any suggestion or just build it as it is?
Old 14th February 2011, 09:00 AM   #39
apexaudio's Avatar
For subwoofer use active x-over on amp input, you can find schematic in post #102 thread: http://www.diyaudio.com/forums/solid...reamps-11.html
Old 22nd February 2011, 06:33 AM   #40
Zoodle is offline Zoodle  Australia
Do you have an ebay store please?
LM3886 Schematics + PCBHide this!Advertise here!
Lm3886 pcb livenicely Chip Amps 33 20th December 2013 10:36 AM
Non inverted, 3 x parallel LM3886 schematics and layout. markiemrboo Chip Amps 0 6th December 2007 12:42 PM
Need schematics and board files for parellel lm3886 clipto333 Chip Amps 5 5th April 2007 04:31 PM
