Old 25th February 2010, 02:59 PM   #1
slopps is offline slopps  United States
Default T-amp bridge? help!
So I'm trying to building a single-speaker i-pod dock and was about to follow the "Reboxing your T-amp" instructions found HERE, assuming I could just bridge the channels to my single speaker when finished.
After further research I now know you can't bridge a T-Amp.
Many songs use the left and right speaker balance purposefully, such as playing the drums in one speaker and everything else in the right speaker. This may sound dumb so please correct me if I'm wrong, but, if I just use one channel of the T-Amp (lets say the left channel) will that be okay or will songs that utilize both left and right speakers totally suffer?
I guess I'm trying to make sure songs are going to play fully through one channel and I won't be missing noises that were specifically sent to the right speaker.
Old 25th February 2010, 08:17 PM   #2
You will need a mixer. You can find an active version in most op amp datasheets.
A simple passive version looks like this.
R1 and R2 have the same value, R3 is optional. The higher the values, the better for the source's output stage, but at the same time the higher the attenutation at the amplifier input.
You will also have to make an assessment about the influence on the amplifier's input filter. The bigger the resistor values, the lower the frequency roll-off of the RF filter.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 25th February 2010, 08:29 PM   #3
Ah okay I see, that makes sense. Thank you.
So it would go something like this?
Ipod -> Mixer -> amp -> speaker
Sorry for the ignorance. I'm clearly very new to this.
Old 2nd March 2010, 05:33 PM   #4
Don't you think it would be a lot simpler to add a second speaker?
I was so much older then, I'm younger than that now.
Old 3rd March 2010, 06:43 PM   #5
Exactly.
Value of Bootstrap capacitor for IR2111 & L6384 Half Bridge Driver xyz9915 Power Supplies 1 27th February 2008 06:32 AM
Reopening an unfinished debate: Dual bridge vs. Single Bridge xiphmont Chip Amps 15 26th February 2008 07:22 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Page generated in 0.07520 seconds (75.79% PHP - 24.21% MySQL) with 10 queries
