| Chip Amps Amplifiers based on integrated circuits |
Sorry for the long post, this is my first time here so I'll give a bit of background and then on to my questions...
This is my first post over here at diyAudio, I've been creeping/poking around for a little while now and have been pretty active over at PE Tech-Talk for the last few years (same tag). I'm pretty good at wiring things up and have worked a a bunch of electro-mechanical projects in school (I've taken a few EE classes but graduated as an MechE). I will eventually want to build a hefty home audio integrated chip amp using a PIC micro controller to control visual output and maybe source selection, etc, etc, but for now I'd like to start out small/simple and eventually when I get acclimated to the water move on to bigger and better(badder) things. SO, actual question(s): I'm looking at using a small(ish) tapped horn for subwoofer duties in my car that will have a sensitivity of 96 dB 1W/1m so I don't need a lot of power. I thought it would be really cool to have a really small packaged amp driving the speaker. I'm looking to get as close to 20 watts as possible into an 8 ohm load. It is my understanding that I can't get more than 25 watts into an 8 ohm load (assuming 14V) because of that whole P=V^2/R issue, is that correct, or is there something that can be about this with bridging/paralleling a chip amp since I only need one output. I would like to do without a SMPS since I'm still quite a novice in this game. Summary: 1 channel 8 ohm load 20 Watts wanted 14 VDC power supply (alternator) Any suggestions or am I going about this in the totally wrong way? -JustinG |
#2 |
So looking around I partially answered my own question. Would something like the 41Hz AMP6-basic or AMP3 kit work for this application or can it not run in a mono configuration?
#3 |
Hi Justin,
We're playing with the inexpensive car chips over here: 12V DC gainclone? <--link Maybe you can find some ideas. |
#4 | |
I was going for the "wow" factor or rather the "really?!" factor with this build telling someone that the 105+ dB they just heard was coming from this little case (amp) and a 7" woofer would be great, but maybe I'll start off with something a bit simpler/conventional for my first build. I'll take a look at those pages and see if anything pops up. My other option is I have a few old amps I no longer use that I may be able to pull the PS out of. After I make my next move ~2 months from now I'll start looking at this stuff more seriously, until then I'll be actively looking around for some good ideas. -Justin |
| Low Powered Inverting Amp (TDA2003) | rossco_50 | Chip Amps | 10 | 29th July 2009 07:31 PM |
| Booster Amp for low powered SET | eeyore | Tubes / Valves | 23 | 26th October 2008 12:05 AM |
| Cheap low powered amp | AutoAudio | Chip Amps | 5 | 16th October 2006 08:21 PM |
| battery powered low power speaker amp | fezz | Chip Amps | 10 | 25th October 2003 12:27 PM |
| Page generated in 0.07189 seconds (75.83% PHP - 24.17% MySQL) with 10 queries |
