| Chip Amps Amplifiers based on integrated circuits |
Hello!
I'm trying to safely get rid of Earth ground loops and I wanted to build this circuit: Earthing (Grounding) Your Hi-Fi - Tricks and Techniques I was wondering if I could use these parts from the ratshack (I don't have the parts on hand): 25A, 50V Full-Wave Bridge Rectifiers - RadioShack.com - 25A full wave rectifier (I know it's not the 35A on the ESP page is that ok?) 10 Ohm 10W 5% Wirewound Resistor (2-Pack) - RadioShack.com - 10 Ohm 10 watt resistor Can't seem to find a 100 nf cap on their site... Will this work? Thanks! --aaron |
#2 |
Ratshack usually has the big FWR squares, I would not skimp on the diodes.
The resistors certainly are big, if you blow a 10w little-0hm resistor you're on your own then... The 100Nf looks like something to help clean up HF's, it'll probably work without it or with a 220nf...until you can source the 100nf. |
#3 |
Thos components are perfect. Just look for any cheap 100nF cap.
This cap is meant to allow pass high frecuency current through it and make the enclosure act as a shield. Low freq current flows through the resistor. I have the same circuit in my main amp and works as a flame
#4 | |
Ps. If you look in the Bryston schematics, you will see they use the same circuit. It does really help to improve THD big time on the meters...With kind regards, Bas |
#5 |
Forgive my ignorance, but what is THD?
#6 |
Total Harmonic Distortion
You can find it here: What is Total Harmonic Distortion? - THD - Definition and Explanation of THD |
#7 | |
David. Edit: http://www.radioshack.com/product/in...isc+capacitors Last edited by davidcb; 23rd February 2010 at 09:02 AM. Reason: Added link. |
#8 |
Slightly OT:
Do yourself a favor and order the big paper catalogs from mouser.com and allied-elec.com, and probably also newark.com. They were free, the last time I checked. They are excellent references to have on hand (and also make finding and ordering components much easier). I usually ended up ordering mostly from mouser.com. Pricing is usually as good as it gets and the minimum order quantity is 1, with no minimum order. |
| Can I solder to this 0.25" terminal or do I need to use a female quick disconnect? | 454Casull | Parts | 5 | 24th February 2009 05:37 PM |
| Mains Disconnect | zenon | Chip Amps | 15 | 8th April 2006 06:12 AM |
| Disconnect CD digital output? | float | Digital Source | 4 | 6th August 2005 12:35 PM |
| Earth again | Pbassred | Solid State | 20 | 10th July 2005 07:44 AM |
| Should I come down to Earth ? | Prof | Chip Amps | 19 | 12th June 2003 02:05 PM |
| Page generated in 0.08410 seconds (79.71% PHP - 20.29% MySQL) with 10 queries |
