Old 20th February 2010, 01:17 PM   #1
Default Help!
Please check my problem here.
LM4870 Noob mess up
Old 20th February 2010, 01:32 PM   #2
acording to your pics you have bare wires all over touching each other and the chassis.do you have any with it compleated? jer
Old 20th February 2010, 01:35 PM   #3
Only transformer and rectifier are connected together at the moment. was gonna connect amps if rectifier was ok. its not
Old 20th February 2010, 03:28 PM   #4
Hi littlerick.
What setting did you have your meter on when testing the rectifier? Are you certain you have your secondaries paired up correctly?
What AC voltage is showing on your secondaries with the rectifier board connected, and what happens with your bulb tester when the power is applied?
John
Old 20th February 2010, 04:02 PM   #5
Meter is set to DC 200v... I have them wired in the colour pairs that it states on label... It is still showing 24.5v at each transformer output....
I didnt use lightbulb tester... Not got round to makin it yet, but I guess I should.
Old 20th February 2010, 11:25 PM   #6
Sparks and the light bulb growing bright sounds like a short-circuit. If that happens when you place the probes, you are either shorting something with either of the probes or you have the probe wires connected to the wrong input of the meter. If the probes are connected for current, you will produce a short through the meter no matter which DC voltage range you set.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 20th February 2010, 11:31 PM   #7
my multimeter has 3 probe inputs.. 1 for negative.. and 1 that says VrmA (r being ohms) and the other says 10ADC.
I have it in 10ADC and dial set to DCV... DCV has 5 settings 200m, 2000m, 20, 200, 1000. I have it set on 200. Is this right?
Old 20th February 2010, 11:53 PM   #8
NO. If you want to measure DC V you need to plug the probe into VRmA (V=voltage, R= resistance, mA= milliAmperes). The ADC connector has nearly 0 impedance towrads the negative connector and produces a short circuit across the board. It could well be that the A range of your meter is fried now.
Old 21st February 2010, 12:03 AM   #9
Maybe I should take up cooking... Frying seems to be my special talent.
Its 1am now, I'm gonna go bed n sleep on it.. Thanks for the help guys, maybe get it right on a fresh day!
Old 21st February 2010, 04:32 AM   #10
naw,keep building we all hit a learning curve sometimes! jer
Page generated in 0.08766 seconds (77.39% PHP - 22.61% MySQL) with 9 queries
