| Chip Amps Amplifiers based on integrated circuits |
Apologies if this has already been covered, being a beginner the more I read on grounding the more confused I get!
The pic attached shows the grounding arrangement suggested by the supplier of the LM3886 boards I just received. I've read around here that signal and power grounds should be kept separate which doesn't appear to be the case here. Any opinions on what should be the ideal set-up would be greatly appreciated. Thanks, Andy |
#2 |
You know I could be wrong but I would only ground the chassis from the side of the board near the transformer.
#3 |
1) Use a star ground at the output of PS board, including one chassis connection ie 3 wires total. (speaker out returns may be best connected here as well)
2) Delete chassis connection at input of the PS board and twist the 3 XFMR secondary wires together. 3) Use shielded or twisted wires at RCA input and float chassis ground at the RCA connectors. 4) Mains safety ground wired directly to chassis. Thus there should only be 2 wires tied to chassis including this.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#4 |
#5 |
Most panel mount RCA jacks (cinch in UK ) have an insulated bushing to keep the outer conductor from contacting the metal mounting panel, thus floating from chassis ground.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 19th February 2010 at 07:57 PM. |
#6 |
Thanks, that makes sense.
So, RCA, power and speaker gnd are each connected to the "star"? |
#7 |
Almost, the RCAs run to amps PCB input. Before you hook things up , redraw your diagram with what I said.
#8 |
Sorry, I meant input, speaker and power connected to the star.
New suggested grounding in green (I foolishly scribbled on the only copy of the schematic I have!) I really appreciate your help with this! |
#9 |
nice
The speaker return from the panel shuns the amp PCB and routes directly to the star ground. so in addition to the grounds, The speaker out has only one wire from the amp PCB and another from star ground on the PS PCB. The input has 2 twisted wires from the amp to the floating RCA.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 19th February 2010 at 09:25 PM. |
#10 | |
Star ground is no good for this case.when connected a source,there are big loop between the source left output <-> unbalanced RCA cable <-> the amp left RCA input <-> left amp pcb <-> star ground point <-> right amp pcb <-> the amp right RCA input <-> unbalanced RCA cable <-> the source right output <-> inner source circuit <-> the source left output.this loop is signal level. So if you set up two or more amp pcb into a single chassis.you have to 'STACK' the ground track on each pcb 'TOGETHER' to pass away the loop between the source & amp. I think a strong ground bar would be better. Can you read this thread? http://www.diyaudio.com/forums/chip-...ml#post1403793 z |
| Gainclone - Grounding | Mareus | Chip Amps | 4 | 13th May 2009 07:22 PM |
| Another Gainclone grounding problem | MikeFarad | Chip Amps | 6 | 9th June 2008 12:22 AM |
| LM3875 SMPS problem pretty sure its my grounding arrangement | justblair | Chip Amps | 16 | 24th March 2007 05:11 PM |
| Gainclone Grounding | Scott_drake | Chip Amps | 10 | 11th February 2007 08:26 AM |
| Grounding of Input Connectors on a Gainclone | saabie22 | Chip Amps | 3 | 13th June 2004 06:12 AM |
| Page generated in 0.10633 seconds (75.06% PHP - 24.94% MySQL) with 11 queries |
