Old 16th February 2010, 02:06 AM   #1
msj965 is offline msj965  United States
Default Need help asap!!!
Hello
Just wanna ask a Q's regarding my cd player.I want to upgrade it's (4) ne5532 op-amps to a better one.Can you recommend me what to buy for?
THanks ,
Ann
Old 16th February 2010, 02:10 AM   #2
Hi, maybe its new,but people on the far east like 5532 very much to this very day, 80's recording gear manufacturers alike. Maybe the results jst wont worth the time spent.
Old 16th February 2010, 02:37 AM   #3
tomchr is offline tomchr  United States
tomchr's Avatar
What's the rush? Jeez...
I'd consider LME49720 or LME49722 (same die, screened for higher operating voltage). Or LME49710 for a single op-amp. Or LME49990 when it becomes available.
~Tom
Old 17th February 2010, 03:12 PM   #4
Default 5532 or others?
I'm checking this opa2132 and ad826 but I don't know if this can work on my system. As a newbie here what do u suggest.
Old 17th February 2010, 03:24 PM   #5
If you can define what about the ne5532 opamp characteristics where it falls short, perhaps a "better" opamp could be suggested.
By something else I mean putting the 5532 in a different scenario might offer more reward than swapping it out for other tries...it's been a time since studying data sheets, after finding some OA's with the performance characteristics for my needs which vary greatly, I found very little differences between suitable candidate opamps in various conditions.
As long as it's a 741 for distortion, and not a 741 for anything else, without some particulars, the Ne5532...isn't that a low noise oa?
Not sure I can name anything that would 'beat' it, the 'other' characteristic being ~precision amplification of the potential difference between the +/- inputs, I can't suggest anything that'd for sure be different enough to hear, even more difficult to discern 'preferred' out of this type of swapping.
For this application [small signal amp I think], the 5532 is a good choice. no?
Old 19th February 2010, 12:14 AM   #6
Send a message via Yahoo to Th3 uN1Qu3
I'd suggest OPA2134 as an affordable replacement. The NE5532 isn't bad, but it's a bit slow, and tends to oscillate in poorly designed PCBs, which either totally ruins the sound if it's in a CD player or preamp, or blows the speakers if it's in the input stage of an amplifier. I've experienced the latter and since then i steer clear of this opamp.
Old 19th February 2010, 04:59 AM   #7
i once replaced all of the opamps in a fostex 450 mixer with ne5532's wow what a diffirence, it sound as good as my mackie 32-8. jer
Old 19th February 2010, 01:28 PM   #8
I've done the same on an old russian crossover (two of the original opamps were fried), and it works just fine. But the crossover has both input and output coupling capacitors. My recommendation still stays, don't use it to control feedback in an amplifier.
Old 19th February 2010, 02:10 PM   #9
pdul is offline pdul  Denmark
You could try some OP275. it is different affordable and i have a good experience replacing 5532`s in a Yamaha cd player before
Old 20th February 2010, 01:11 AM   #10
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
you will need a meter to check the dc voltage between pin4 to pin8 of the ne5532.
is it these ne5532 solder on the pcb?it is a hardship.
z
soundstream help ASAP audiobahnkid592 Car Audio 3 12th March 2009 09:59 PM
Need Help Asap msj965 Parts 2 12th February 2009 02:44 AM
XO help ASAP VictorG Multi-Way 2 12th August 2003 03:45 AM
Page generated in 0.09776 seconds (78.97% PHP - 21.03% MySQL) with 10 queries
