Yet Another LME49811 + STD03 Build - Page 9 - diyAudio
Old 5th June 2010, 12:39 AM   #81
panson_hk's Avatar
Hi Tom,
Under what operating condition you measured ten fold THD difference?
Panson
Old 9th June 2010, 07:31 PM   #82
tomchr is offline tomchr  Canada
tomchr's Avatar
I don't remember exactly. I was running on a +/-25 V supply that could supply 1 A, so the output power would have been limited to about 4 W RMS into 8 ohms. I suspect this was the condition I used for the test. Could have been 1 W, though. I'm fairly certain I was measuring at 1 kHz.
~Tom
Old 10th June 2010, 12:44 AM   #83
panson_hk's Avatar
Thank you Tom.
Old 11th June 2010, 07:05 AM   #84
panson_hk's Avatar
Default Square wave test with cap load
Here are some waveforms of square-wave with capacitive load. Output level is 20 Vpp. An output coil with 10R damping resistor is employed.
Old 11th June 2010, 10:09 PM   #85
Dear Panson,
Thanks for sharing.
Do you also have a 20KHz Square-wave plot on a pure resistive load? I think you should slightly increase the miller compensation to avoid the overshoot.
Of course, more important, we are all curious how does it sound?
With kind regards,
Bas
Old 13th June 2010, 11:20 PM   #86
panson_hk's Avatar
Hi Bas,
Here is 20 kHz square wave (20 Vpp) without cap load. I currently use 32 pF. I will assemble another board to make a stereo amp for listening.
Panson
Old 18th November 2010, 05:00 AM   #87
Thank you Tom for this good explanation. It makes me understand the function of the cap. Did you also experiment with different values?
Hey, 'bas, apropos of the discussion over here I noticed your early schematic shows 100nF || 47uF and later ones 100nF || 22uF. Did you happen to wind up with any comparative data between the two?
Old 22nd December 2010, 07:13 PM   #88
tomchr's Avatar
Default Final schematics
Folks,
I finally got around to updating the schematic with a few component changes and some annotation. See attached.
The amp has been playing quite happily for months now. The design seems solid. Even after some 8~9 months in service, the bias is still rock solid at 41 mV for the left channel, 42 mV for the right (across 440 mOhm - target value: 40 mV). Given how finicky it is to adjust, my bet is that the bias hasn't moved more than 1 mV from its initial value. That corresponds to 2 mA (or 2 %).
~Tom
Old 15th June 2011, 07:16 AM   #89
Hello,
I had to remove the capasitors between bases parallel after Vbe multiplier.Not because stability or something else,but because with the caps the mute control of lme49811 don't 'work correctly. To put in play mode was ok,but when i remove the voltage from sd pin the amp makes the ugly noise.The output goes negative with some ac noise and comes back slowly while my caps discharge. Current to sd pin 1.5ma. Tried sd pin to put to ground momentary as said in datasheet,but no sucsess. Looks like somehow these caps discharge through internal lme circuit after sd is put in mute mode.Without caps mute works fine.Changing from play mode to mute i can hear short click only few inches from tweeter.Anyone experienced this ? I am wondering how in lme49811 mute is implemented?
Old 15th June 2011, 08:06 PM   #90
Had to put back the capasitors because the performance was degraded. But the mute still mistery not solved.
LME49810/STD03 parallel pairs Sebastiaan Chip Amps 109 20th February 2010 03:32 PM
LME49811 Questions db! Chip Amps 37 10th February 2010 01:25 PM
lme49811 and lme49830 selling authlxl Swap Meet 0 13th January 2010 06:29 AM
Class A with LME49811... Dxvideo Chip Amps 22 2nd November 2009 02:11 PM
WTB: Sanken SAP15N + SAP15P (or SAP16 - STD03) Vil Swap Meet 3 22nd July 2009 06:10 PM
Copyright 1999-2017 diyAudio
