| Chip Amps Amplifiers based on integrated circuits |
#91 |
I started out without the capacitor across the bias spreader, but found that I could get a significant reduction in THD (I think 10x improvement, but I don't recall exact numbers) by adding the capacitor. So I put in 10 uF (I think it was) and left it at that. In his Power Amplifiers book, Bob Cordell includes a bit on why the capacitor is there and how it works. I forget the details, but the gist of it is that the bias spreader should be as close to a voltage source as possible at all relevant frequencies.
You can try to reduce the value of this cap to 1 uF or 100 nF to see if that gives you a good tradeoff between mute functionality and THD. ~Tom |
#92 |
Are you mounting the diode stack on the heat sink for thermal compensation? Thx. smg
#93 |
The STD03N, STD03P output devices are ThermalTrak (TM) devices. This means they have a built-in diode stack on the same die as the transistor itself. So not only is it mounted on the heat sink, it's on the same die attach paddle, and most likely on the same die.
Whether the diode is on the DAP or the die depends on the manufacturer. You'll have to consult with the relevant data sheets or app notes for that information. ~Tom |
#94 | |
I have no idea for this problem ...
| LME49810/STD03 parallel pairs | Sebastiaan | Chip Amps | 109 | 20th February 2010 02:32 PM |
| LME49811 Questions | db! | Chip Amps | 37 | 10th February 2010 12:25 PM |
| lme49811 and lme49830 selling | authlxl | Swap Meet | 0 | 13th January 2010 05:29 AM |
| Class A with LME49811... | Dxvideo | Chip Amps | 22 | 2nd November 2009 01:11 PM |
| WTB: Sanken SAP15N + SAP15P (or SAP16 - STD03) | Vil | Swap Meet | 3 | 22nd July 2009 05:10 PM |
