| Chip Amps Amplifiers based on integrated circuits |
Title says it all. My transformer choice is +/-22v.
Interested to know your thoughts, as this seems to be an intermediate speaker impedance and it is difficult to know which way to go. I'm thinking parallel would be best... Thanks, Greg. |
#2 |
Single 4780 channel is not 3 ohm capable, hence parallel is the only way out.
#3 |
#4 |
If you bridge an amplifier, each amplifier channel will see half of the load impedance, meaning 3 ohms here.
/U. |
#5 |
#6 |
I would be tempted to say the two channels inside a 4780 are not 4ohm speaker capable, but that many use them into this more demanding load and find the results good enough.
6r0 could demand upto 5Apk. A parallel 4780 can output upto 14Apk to a load. A pair of 4780 channels fed from 22+22Vac should have sufficient current capability to drive a reactive 6ohm speaker load without triggering Spike or any other limiting if you can keep the chip cool. There is your problem.
regards Andrew T. Last edited by AndrewT; 15th February 2010 at 02:08 PM. |
#7 |
Still parallel operation is more viable solution for 6 ohm @ normal listening levels, provided u don't use speakers at full volume.
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout |
#8 |
Banned
If I get the PD 4870 kit and wish to run parallel monoblocks all I need to do is add the extra parts to the pcb and get two tranies correct? And that will put me at about 100w per channel at 8 Ohm?
#9 |
Parallel will still produce up 60W into 8ohm, to get more power you need to use 4 ohm speakers.
Two tranies are required for dual mono, more info on the kit here: Kit arrived
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#10 |
You must also keep in mind that an amplifier output voltage swing is determined by the power supply's RMS voltage minus 2.5v to 3.5v (see data sheet) because it can't swing compleatly to the rail and not the peak voltage as measured at the filter capacitor.
therefore with a 22v transformer it can only produce less than 80 watts into a 6 ohm load. At least a 26v-0-26v transformer should be considered and a 28v-0-28v would be optimum to get a full undistorted 100watts into 6ohms. I have seen this question time and time again and this has never been mentioned or discussed. Yes,a higher power supply voltage means warmer chip temps,just use an adequate heatsink and you shouldn't have any problems. jer |
| Bridged 4780 for 4ohms load? | jaste | Chip Amps | 18 | 26th May 2010 04:46 PM |
| 4780 stereo, parallel, bridged, single sided | gmphadte | Chip Amps | 12 | 12th March 2007 11:42 AM |
| Bridged 4780 with 35V rails | akunec | Chip Amps | 0 | 20th October 2004 12:25 AM |
| 4780 Bridged PCB designs? | Nappylady | Chip Amps | 0 | 28th April 2004 05:25 PM |
| Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better? | Cal Weldon | Multi-Way | 16 | 21st February 2004 12:31 AM |
| Page generated in 0.10053 seconds (79.89% PHP - 20.11% MySQL) with 10 queries |
