Would you use a 4780 in a parallel or bridged configuration with 6 ohm speakers?
Old 14th February 2010, 04:17 AM   #1
GregH2 is offline GregH2  Australia
GregH2's Avatar
Default Would you use a 4780 in a parallel or bridged configuration with 6 ohm speakers?
Title says it all. My transformer choice is +/-22v.
Interested to know your thoughts, as this seems to be an intermediate speaker impedance and it is difficult to know which way to go. I'm thinking parallel would be best...
Thanks,
Greg.
Old 14th February 2010, 06:33 AM   #2
sangram is offline sangram  India
Single 4780 channel is not 3 ohm capable, hence parallel is the only way out.
Old 14th February 2010, 09:18 AM   #3
GregH2's Avatar
Hi Sangram,
Thanks for your reply, however I am confused. What does 3 ohms have to do with anything when my speakers are 6? Could you please explain?
Thanks,
Greg.
Old 14th February 2010, 09:25 AM   #4
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
If you bridge an amplifier, each amplifier channel will see half of the load impedance, meaning 3 ohms here.
/U.
Old 14th February 2010, 09:31 AM   #5
GregH2's Avatar
/U.
OK, fantastic thanks. Parallel operation it will be then.
Greg.
Old 15th February 2010, 03:04 PM   #6
AndrewT is online now AndrewT  Scotland
I would be tempted to say the two channels inside a 4780 are not 4ohm speaker capable, but that many use them into this more demanding load and find the results good enough.
6r0 could demand upto 5Apk. A parallel 4780 can output upto 14Apk to a load. A pair of 4780 channels fed from 22+22Vac should have sufficient current capability to drive a reactive 6ohm speaker load without triggering Spike or any other limiting if you can keep the chip cool. There is your problem.
regards Andrew T.
Old 16th February 2010, 01:33 PM   #7
kuldeepsingh is offline kuldeepsingh  India
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh
Still parallel operation is more viable solution for 6 ohm @ normal listening levels, provided u don't use speakers at full volume.
My Blog
Old 13th May 2010, 01:01 PM   #8
olblueyez is offline olblueyez  United States
Banned
If I get the PD 4870 kit and wish to run parallel monoblocks all I need to do is add the extra parts to the pcb and get two tranies correct? And that will put me at about 100w per channel at 8 Ohm?
Old 13th May 2010, 01:36 PM   #9
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Would you use a 4780 in a parallel or bridged configuration with 6 ohm speakers? Send a message via AIM to Peter Daniel
Parallel will still produce up 60W into 8ohm, to get more power you need to use 4 ohm speakers.
Two tranies are required for dual mono, more info on the kit here: Kit arrived
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 13th May 2010, 02:49 PM   #10
geraldfryjr is offline geraldfryjr  United States
You must also keep in mind that an amplifier output voltage swing is determined by the power supply's RMS voltage minus 2.5v to 3.5v (see data sheet) because it can't swing compleatly to the rail and not the peak voltage as measured at the filter capacitor.
therefore with a 22v transformer it can only produce less than 80 watts into a 6 ohm load.
At least a 26v-0-26v transformer should be considered and a 28v-0-28v would be optimum to get a full undistorted 100watts into 6ohms.
I have seen this question time and time again and this has never been mentioned or discussed.
Yes,a higher power supply voltage means warmer chip temps,just use an adequate heatsink and you shouldn't have any problems. jer
Would you use a 4780 in a parallel or bridged configuration with 6 ohm speakers?Hide this!Advertise here!
Bridged 4780 for 4ohms load? jaste Chip Amps 18 26th May 2010 05:46 PM
4780 stereo, parallel, bridged, single sided gmphadte Chip Amps 12 12th March 2007 12:42 PM
Bridged 4780 with 35V rails akunec Chip Amps 0 20th October 2004 01:25 AM
4780 Bridged PCB designs? Nappylady Chip Amps 0 28th April 2004 06:25 PM
Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better? Cal Weldon Multi-Way 16 21st February 2004 01:31 AM
