| Chip Amps Amplifiers based on integrated circuits |
I found in national web "Performance Audio"class no LME49610. http://www.national.com/cat/index.cgi?i=i//305
BUT:At the LME49610 web :LME49610 - High Performance, High Fidelity, High Current Audio Buffer It said is in "Performance Audio" Why ? it is not on sale now? And What's the difference Between LME49600 and LME49610? Thanks. |
#2 |
The LME49610 has a higher quiescent current and somewhat wider bandwidth, based on the summary on the web site. It also operates on higher power supply voltages (+/-22V max vs. +/-18V). There may be other differences if you carefully compare the two datasheets.
bel |
#3 |
I'm not sure what you mean by "why ? is not for sale". It is a released part. According to National both Digikey and Future have them in stock. See the Order page in the LME49610 product page.
As far as the difference between LME49600 and LME49610, it looks to me like National is screening the parts out that can handle the higher supply voltage and selling them as '610s. The ones that start drifting off spec above 18 V are sold as '600s. That would be my guess. They do the same with the LME49720 and LME49722 supposedly. ~Tom Last edited by tomchr; 15th February 2010 at 05:30 AM. |
#4 |
It looks like they needed a higher voltage buffer to go with the higher voltage op-amp. I agree with Tom that they appear suspiciously alike.
bel |
#5 |
For the LME49610, I notice that the Vout margins are smaller, and Isc-out is 750ma. Iout is still 250ma though. Has anyone used both? What is the rms current output?
| LME49600/LME49740 Headphome Amp | theAnonymous1 | Solid State | 28 | 31st January 2010 03:25 AM |
| is there a difference? | moray james | Everything Else | 91 | 11th November 2009 09:23 PM |
| What's the difference? | squirtacious | Tubes / Valves | 4 | 23rd October 2007 04:38 AM |
| difference between 1 and 2 | androtaker56 | Car Audio | 9 | 14th November 2005 12:36 PM |
| Different brands:Is there any difference? | specter73 | Tubes / Valves | 8 | 10th June 2005 05:59 AM |
