Old 12th February 2010, 12:27 AM   #1
Default On/Off Switch Short Circuit
I just constructed a simple 10W stereo amplifier for some small speakers and it all worked fine until I wired in the SPST on/off switch. The circuit still works fine when the switch is in the "on" position but once I turn it "off", the 9V battery I am using for a power source begins to heat up as if it is short circuiting. Any suggestions? Thanks!
Old 12th February 2010, 12:50 AM   #2
lanchile's Avatar
How did you wire it up? Can you show the way you did it?
Old 12th February 2010, 01:44 AM   #3
Sorry, this is the only drawing tool available at the time. It's a really simple circuit other than the amplifier, but I don't believe the amp has the problem because it works fine when there is no switch or if it is in the "on" position. I must have wired the switch wrong somehow. It has been a while since I wired anything...
File Type: png Screen shot 2010-02-11 at 8.40.39 PM.png (13.1 KB, 98 views)
Old 12th February 2010, 02:26 AM   #4
Perhaps I simply need more amps? Would wiring 6 AA batteries in series be a better shot than my single 9V?
Old 12th February 2010, 02:29 AM   #5
Speedskater's Avatar
The black wire should not be connected to the switch!
The black wire from the battery connects only to the PCB.
The red wire from the battery connects to one terminal of the switch.
The red wire to the PCB connects to the other switch terminal.
Kevin
Old 12th February 2010, 02:55 AM   #6
lanchile's Avatar
you have it wrong! you are shorting the battery that is why it gets hot!
just fallow Kevin suggestion!
Old 12th February 2010, 03:46 AM   #7
Ah, thank you! I can't believe I forgot such a simple thing. Thank you so much!
Old 12th February 2010, 09:50 AM   #8
frank1 is offline frank1  United Kingdom
Default A picture is worth a thousand!
short circuit protection roofingboom Solid State 109 1st May 2012 02:28 PM
Overload and Short Circuit Protection space2000 Solid State 17 5th March 2009 10:26 PM
short-circuit rectifier EZ80 ! jpweaner2 Tubes / Valves 4 6th May 2007 04:48 PM
Short circuit protection MiiB Solid State 0 16th May 2006 06:48 AM
Short circuit protection JBL Solid State 20 5th August 2002 07:27 AM
Page generated in 0.07671 seconds (84.43% PHP - 15.57% MySQL) with 11 queries
