Old 11th February 2010, 09:43 PM   #1
gunny1 is offline gunny1  Canada
Default Which IC amp for +/- 42 Vdc?
I was given a Peavey mixer amp (mono) with a totally smoked power amp section. It's model 200H rated 100 Watts into 4 Ohms. I don't wish to restore the power amp section, I'd rather just build or buy a new chip amp.
Here's the question: the DC power supplies are both A-OK. +/-42 Vdc and +/-16 Vdc (to operate the mixer/pre-amp). The mixer is working fine.
I realize that 84 Vdc is the max rated applied voltage on spec sheets for 3875, 3886 chip amps.
Any suggestions on which amp circuit I could build or buy and still be able to use the power supply I have?
It's not imperative that I get 100 Watts out of it; just something over 30 Watts would be fine.
Old 11th February 2010, 09:47 PM   #2
frugal-phile(tm)
planet10's Avatar
I have a 3875 chipamp running on just a bit over the maximum. It sounds very good when driving high impedance loads (16 ohms, not as good when the impedance starts dropping)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th February 2010, 10:20 PM   #3
infinia is offline infinia  United States
infinia's Avatar
you could get a ready made kit on ebay $10-20 along with a new $10 transformer and rewire the old powersupply;
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 11th February 2010, 11:34 PM   #4
Minion is offline Minion  Canada
Try a TDA7293/94 , it will put out close to 100w into 8 ohms , A Pretty good sounding chip , I"m useing one in a Guitar amp at +/42Vdc and it sounds nice , it won"t drive 4 ohms at +/-42v , you would need a lower Voltage to drive 4 ohms like +/-30Vdc .....
Old 13th February 2010, 06:23 PM   #5
if you parallel 3 or 4(one leg of a bpa 300) of them you shouldn't have any problems when driving 4 ohm loads common in pa speakers.jer
Old 15th February 2010, 03:53 AM   #6
i forgot to specify lm3886
Old 15th February 2010, 04:04 AM   #7
Thanks for all the replies. I've struggled with the decision on whether to use 3886 or the 7293/4 but decided to use the TDA2050 powered from the +/-18 Vdc that's also available on the parent circuit.
The main reason I didn't use the typical 'clone' variety amp chip was that I didnt' want to risk operating at the maximum Vs for 7293 and wanted to use the existing power transformer.
The kits for clone circuits were attractive but since I'm not using this in a stereo application, I'd be wasting half of the board.
Let's consider this thread closed. Thanks again to all.
Old 16th February 2010, 10:42 AM   #8
If the power supply has ±18 and ±42 V the TDA7293/94 is the right choice in class H configuration. The datasheet calls it High Efficiency Application Circuit (Figure 6, Page 9).
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 16th February 2010, 03:58 PM   #9
infinia's Avatar
Its doubtful that the added demands placed on the existing +/-18 Vdc can support a Power Amp driving a 8 ohm or perhaps 4 ohm speaker. Before your decision can be finalized you must verify that the XFMR windings and rectifier can tolerate this without blowing. Be very careful when testing as it very easy to pop these lighter windings. Me I wouldnt even go there.
Old 18th February 2010, 10:31 AM   #10
Infinia: absolutely correct. I will use one half of the PT's main secondary winding instead +42 Vdc to CT and operate the TDA2050 in single rail mode. The PT won't be overloaded - I'll be using the half winding at ~80% of what it can deliver current-wise.
I know 7293/4 would work using the full transformer output but my speaker's aren't rated that high.
12 vdc to 18 vdc isolated P-P jamesrnz Power Supplies 89 4th February 2009 03:36 PM
48 VDC/10 A power supply looking for an Amp design Analog Addict Solid State 16 16th January 2008 10:39 AM
FS: Carver TFM-42 375WPC power amp pkpickard Swap Meet 0 18th November 2005 11:50 PM
0-42 0-42, 1500VA Toroidals richie00boy Group Buys 10 23rd November 2004 11:24 PM
FS: (2) 28 VDC 11 AMP regulated power supplies. FEThead Swap Meet 1 2nd May 2002 04:18 PM
Page generated in 0.10058 seconds (81.54% PHP - 18.46% MySQL) with 10 queries
