Old 7th February 2010, 09:46 PM   #1
GAH is offline GAH  Fiji
Default Bi-amping - Bridged LM3875 & LM4780
I'm considering biamping my two channel sound system with two dual mono bridged gainclone amps (Peter Daniels kits) - Bridged LM3875 (High-Freq) and Bridged LM4780 (Bass-Freq).
Are the gains of the LM3875 & LM4780 chips closely matched for effective use in a biamp configuration? Or would I be better off using the same model chip?
Would there be any real sonic advantage biamping using these gainclones when using a 6 ohm nominal impedance speaker (Living Voice)? I understand in bridge mode the load is halved but my existing bridged LM3875 amp drives these speakers nicely without breaking a sweat.
BTW, the LM3875 bridged amp uses Black gate caps and LM4780 bridged amp uses Panasonic caps as designed by Peter Daniel.
Old 8th February 2010, 05:18 PM   #2
If both kits are from the same source, they have the same gain (22k/680r).
Biamping is always advantagous. How much advantage there is, depends on the speakers and the crossing frequency.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 8th February 2010, 07:43 PM   #3
Thanks Pacificblue
Bridged LM4780 Amp jackinnj Chip Amps 17 24th March 2011 04:36 AM
PP tube amp for bi-amping : above 400 hz operafan4 Tubes / Valves 1 9th January 2010 04:08 PM
Need help in building Ucd module based power amp for bi-amping Halook Class D 6 4th January 2010 02:47 PM
Sonic Impact T-Amp - Is bi-amping better? ac2005 Class D 1 29th July 2005 09:28 PM
What to do with a handful of LM3875's-Bridged, parallel, bi-amp etc? Dr.H Chip Amps 7 10th August 2004 04:21 PM
Page generated in 0.06533 seconds (70.65% PHP - 29.35% MySQL) with 10 queries
