2 or 4 bridges? - diyAudio
Old 5th June 2003, 02:02 PM   #1
Raka is offline Raka  Europe
Raka's Avatar
Default 2 or 4 bridges?
just a small question:
I connected my gainclone to a 250VA 18V trafo, with two bridges, and sounded ok (not enormous, but ok). I thought that if there were four bridges (that is one per rail, two per channel) I will have two nice power supplies sharing the trafo, supposed to be good thing.
Well, I fired it up and...
The diodes started to get bored and decided to BOOOMMMM to have a laugh at me.
I don't know if I made a connection mistake, but my question is if there are advantages using 4 bridges?
Don't tell me to try, because I run up of diodes: 16!
What is beyond the speaker?
Old 5th June 2003, 02:46 PM   #2
Are you only one transformer?
Mark
Old 5th June 2003, 03:02 PM   #3
Raka's Avatar
Yes, I'm using only one transformer. Is possible to use only one transformer and 4 bridges?
Old 5th June 2003, 03:12 PM   #4
JOE DIRT®'s Avatar
give us an idea on how you hooked it up>????
Old 5th June 2003, 03:32 PM   #5
Raka's Avatar
Well, I duplicated the bridges, two for channel, and then connect the trafo to the input of the bridges. so simple, isn' it?
For each output wire of the trafo I derived two wires to each input of the bridges. Would be there any problem with this? Do I short anything this way?
Old 5th June 2003, 03:39 PM   #6
JOE DIRT®'s Avatar
thats fine on what you did with the bridges....now lets say you have 2 + and 2- ...off each bridge....how are they hooked up to each channel?
Old 5th June 2003, 03:53 PM   #7
Raka's Avatar
Something like that
Old 5th June 2003, 04:25 PM   #8
sam9 is offline sam9  United States
sam9's Avatar
I'm not sue I understand the issue. The transformer gives you 250VA to work with. Adding bridges isn't going to change that. As long as it can handle the current, a single bridge is normally sufficient. One rated 25A-35A with a metal case and bolted to the bottom of the enclosre ought to be adequate. There are arguments for one bridge per rail, but those seem to be to compensate for a problem somewhere else.
Old 5th June 2003, 04:57 PM   #9
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
two bridges are supposed to sound better, I'm just in the process of building a 16 diode PSU.
but apparently it's best to run 4 wires to each amp & connect the two grounds at the earth star in the amps.
cheers
mike
Old 5th June 2003, 04:58 PM   #10
Looking at the diagram, it ought to work fine. I suspect that you made a mistake during hook-up, or one of the bridges is faulty. Try separating the earth connections of the two channels, and measuring the potential difference between them...
As far as I know, this is the theory behind seperate rectifiers for each channel: a loud sound in of the channels causes the supply rails to fall slightly because of the increased current demand - with common rectifiers, the other channel will see its supply rails fall, and the stereo image might suffer as a result.
I'm not sure how much of a problem this is in practice, and I'd be worried by the extra complexity and scope for errors bought about with the extra rectifiers. I'd also be worried about the "cleanness" of the earth connection, because although they come from the junction of seperate rectifiers, they get tied together by your star-earth (or preamp or source if you maintain seperate L/R star earths)
When I was using a single transformer, I stuck to common bridge rectifiers for both channels. For what it's worth, I think it's far better to go for completely seperate power supplies - mains transformers aren't too expensive really...
Mark
Parallel bridges? Skorpio Power Supplies 6 27th June 2009 05:56 AM
two bridges on one secondary jpfastre Solid State 10 3rd January 2007 09:13 PM
tda2030, bridges vlljpior Chip Amps 2 29th September 2006 07:54 AM
Bridges for life ! mpmarino Parts 4 11th December 2004 11:11 PM
Why two bridges are better than one? Andypairo Pass Labs 14 15th October 2002 01:25 AM
Copyright ©1999-2017 diyAudio
