| Chip Amps Amplifiers based on integrated circuits |
Hey guys,
I am planning a LME49811 build since I already have the IC and a few 120VCT toroids that I'd like to put to good use. These transformers should yield approximately 180VDC or +/- 90VDC; this is very close to the limit of LME at 200V. Since I have no experience in designing an output stage, I've been looking around the web and I stumbled upon this: 300/500W Subwoofer Power Amplifier The diagram I am referring to is the second one down. Now for the big question; will it work properly without any extreme modifications/experimentation? I plan to use a much higher voltage (+/- 90VDC) instead of the +/- 56v in the original circuit; are there going to be any problems? By running it at my intended voltage, would I be noticeably reducing the life of the transistors? In case circuit above is not suitable, are there any other designs that are more ideally suited? I would prefer something that doesn't use Japanese/exotic transistors; it's hard to find genuine parts and they tend to go obsolete rather fast. I apologize my questions seem trivial/stupid; this is quite a step up from my previous gainclone project (LM3875). Any advice/info would be greatly appreciated! Last edited by db!; 5th February 2010 at 06:12 AM. |
#2 |
From Rod's site
"Do not even think about using supplies over ±70V, and don't bother asking me if it is ok - it isn't!" So don't! What you can consider though to reach higher power levels is to build two of those amplifiers and bridge them. But then you need a even lower power supply voltage. With kind regards, Bas |
#3 |
6pair of mjl4281/301 will just about do 400W into 8ohm from +-87Vdc.
8pair will do about 750W into 4ohm if you can keep them cool enough. I assumed +-75mF, 4% regulation, Re=0r27, 60degree phase angle, Tc<45degC 6pair of MJ21193/4 will do 4ohms, Tc<60degC
regards Andrew T. Last edited by AndrewT; 5th February 2010 at 12:38 PM. |
#4 | |
AndrewT - Can I wire the transistors the same way as seen in the schematic? |
#5 |
There is one way to use your transformers which is paralleling the secondaries in order to supply bridged amplifiers using a floating ground. This halves the voltage between the two rails...
in your case +/- 45v rails. Last edited by bobodioulasso; 5th February 2010 at 06:38 PM. |
#6 | ||
That said, as long as you can guarantee that your supply won't get above 200 V under the worst case conditions, there should not be any issue using the LME49811 IC for your amp. There will be some margin on the specified 200 V abs max for the LME49811. Look at the abs max number as the absolute maximum continuous operating voltage ever reached in your design under worst case conditions (including power line fluctuations). Quote:
The topology for Rod's amplifier is covered stage-by-stage in many college textbooks. My favorite is Sedra/Smith. Given the voltage levels that you throw out, I would strongly recommend that you fully understand the circuit - and preferably run some simulations of it at the voltages you mention - before building and testing it. If Sedra/Smith is above your head, then I'd recommend building a kit such as the ones offered by Panson Audio. Panson is pretty active in this forum as well. I have no personal experience with his kits but judging from his contributions on the forum, I have no reservations about recommending them. Good luck! ~Tom |
#7 | |
I would like to drive the LME49811 close to it's maximum rating to get maximum output.The only problem I have is designing/finding an output stage that can put out 500W. When you mention paralleling the secondaries of the transformer, do you mean paralleling the 2 transformers? The toroids I have only have a single 120VCT secondary... Tomchr - I am aware of the the voltages I intend to operate the amp at are dangerous. I've been in the HV scene for a while so I am fully aware of all the safety precautions. I'll probably use a variac to slowly increase the voltage before hitting it with the full 180V. As for Rod's circuit, I am only interested in using the output stage for the LME. I appreciate all the info guys! Last edited by db!; 5th February 2010 at 07:40 PM. |
#8 | |||
![]() ~Tom |
#9 | |
#10 |
Is your project intended for PA or HIFI?
If HIFI you can google for Rotel RB1090 and get the schematic. I have copied this output stage designed for 90 volts rails and i use a LME49810 as driver. I must say i have been running it at 63v rails only for now. Last edited by bobodioulasso; 5th February 2010 at 09:40 PM. |
| LME49811 + Sanken STD03N/P | jackinnj | Chip Amps | 33 | 8th November 2011 03:08 PM |
| LME49811, bridged, DC servo, Thermaltrak | Sebastiaan | Chip Amps | 17 | 11th February 2010 07:31 PM |
| lme49811 and lme49830 selling | authlxl | Swap Meet | 0 | 13th January 2010 05:29 AM |
| Class A with LME49811... | Dxvideo | Chip Amps | 22 | 2nd November 2009 01:11 PM |
| LME49811 front-end for Gilmore amp? | Artie | Solid State | 7 | 29th April 2009 08:36 PM |
| Page generated in 0.13139 seconds (85.89% PHP - 14.11% MySQL) with 11 queries |
