| Chip Amps Amplifiers based on integrated circuits |
Guys, how much gain one of Brian Bell's LM3875 kits has? I haven't heard back from him and wanted to check in here to see if anyone knew offhand.
Thanks all, Jim |
#2 |
It's 30dB, but you can change the value by replacing the feedback resistors.
Any solution is a compromise. |
#3 |
the dB gain is 20 * Log(voltage gain)
the voltage gain for inverting is Rf/Rb the voltage gain for non-inverting is {[Rf /Rb] + 1} You must also correct for the loss at the input. (-dB)
regards Andrew T. |
#4 |
Thanks guys. ratza, which resistors are these and what values would I need to get to 26db of gain?
-Jim |
#5 |
Replace the 680R resistor with 1k (27.2dB), 1k1 (26.4dB) or 1k2 (25.7dB).
| dB Gain with Series vs. Parallel Wiring | 69stingray | Multi-Way | 16 | 21st November 2005 01:45 AM |
| db, gain, and loudness. Simple math | Pbassred | Multi-Way | 16 | 8th November 2005 03:13 PM |
| passive bandpass dB gain, what is to much? | scott beavers | Subwoofers | 1 | 26th October 2005 04:18 PM |
| dB Room gain in a midbass horn | rick57 | Multi-Way | 2 | 13th January 2005 12:34 PM |
| dB into voltage gain???? | AudioGeek | Tubes / Valves | 6 | 17th April 2004 01:25 PM |
| Page generated in 0.07079 seconds (72.43% PHP - 27.57% MySQL) with 10 queries |
