| Chip Amps Amplifiers based on integrated circuits |
I just build an car amplifier using single(one) Tda1562, but i like to upgrade with output transistors, or to connect two amplifiers in paralel(in- with in-; out+ with out+; gnd with gnd.) So, can somebody help me please?
#2 |
I am a newbie, so I can't answer you question. But I have one of my own. What did you use for volume control, as well as tone control? (See my new thread.)
The Happy Hippy |
#3 |
Please do a search on this forum for TDA1562 and read all the hits. If you still have questions then post your specific question and you will receive many responses.
You have many options. |
#4 |
To achieve what?
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#5 |
to get more amps, e.c. to connect 1(2x2 in parallel)ohm speaker.
#6 |
In theory it is possible to connect those ICs in parallel. In practice it takes well matched feedback circuits, if you don't want to run into trouble. It is not very likely that they are well matched, and since they are internal you cannot do anything about it. You may be better off connecting the 2 x 2 Ohm speakers in series, which gives you 4 Ohm.
The transistor solution is also not likely to work well, because the TDA1562 is internally a class H amplifier. You will need an additional (24 V?) power supply to get the corresponding higher supply voltage for the external transistors. The TDA1562 is also internally a bridged amplifier, which means you need double the amount of transistors as compared to a normal chipamp with transistors. In the end this will turn out to be pretty complicated and expensive.
#7 | |
What do you think of LA4628 with 8 output transistors? According to MCM, that chip is "often purchased with Sanken output transistors" however, other clues on this tempting prospect, were absent. How does one make such an amp? |
#8 |
I don't think much of adding transistors to power op amps. You need to add an external bias stage for the power transistors, although you already have one inside the IC and you don't make good use of the internal power transistors.
For designers who cannot or will not design their own driver stages, the industry offers driver ICs, e. g. TDA7250 or the LME49800 series. The LA4628 is an internally bridged 20 W into 4 Ohm amplifier that runs from a 13,5 V single supply. You would need one pair of transistors and a bias stage for each output pin to get the two bridged output stages. The result would be increased output current and THD with decreased output voltage.
#9 | |
![]() Well, of course the output stage in this case would have to run higher voltage. ![]() The effort to boost a chip amp is looking pretty silly because it requires the majority of a discrete amp to do it. lol! Oh, I get it now. You would normally expect more work for less results, except. . . Personally, that wasn't my point. My reason for asking is that great sounding, ear-friendly, chips do exist, some are very clean, and some, like LM1875 come with a endearing performance that verges into areas we have only begun to measure. They have only one thing in common, and that is, insufficient output power. So, it seems that a good reason (maybe the only good reason) to use a power op amp as a pre-drive is that you happen to like its harmonic output. One would not expect the "booster" effort to make any more or any less audio degradation than adding a preamplifier to an audio system that doesn't require it. Is this bit correct? |
#10 |
That would not help. The driving stage determines the output voltage.
| Car Amp using TDA1562 by Philips | Junior | Car Audio | 14 | 10th February 2011 05:59 PM |
| Tda1562 upgrade or paralel | bicikle | Car Audio | 2 | 1st February 2010 02:50 PM |
| Are my two TDA1562 destroyed?? | newbadboy | Chip Amps | 2 | 10th June 2009 12:13 PM |
| Low Power Output with TDA1562 | pedopapa | Car Audio | 3 | 14th October 2005 01:11 PM |
| Page generated in 0.10288 seconds (83.07% PHP - 16.93% MySQL) with 10 queries |
