Old 9th February 2010, 11:52 AM   #21
peranders, I'm gonna measure and see if I find something. Yes, I'm pretty sure that every resistor have the right value, I measured them all before installing them.
Old 9th February 2010, 07:04 PM   #22
200 mV / 33,35 = 6 mV at the input. 6 mA across a 22k resistor corresponds to 0,27 µA. Above the typical value, but well within the LM4780's specs.
3,5 V / 33,35 = 105 mV at the input, which corresponds to ~4,8 µA. That is too much. The other way round, if 0,2..1 µA produce 3,5 V, there must be 3M5..17M5 involved, which would mean the 22k resistor is either open circuit or you need to check the solder joints.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 9th February 2010, 08:09 PM   #23
Electrons are yellow and more is better!
peranders's Avatar
Remember that the 22k goes to two LM4780 => double input bias current
/Per-Anders (my first name) or P-A as my friends call me
Old 10th February 2010, 07:34 AM   #24
When I measure directly from input to the chassi ground I get 22k, shouldnt that mean that the resistor does its job?
Old 10th February 2010, 08:30 AM   #25
peranders's Avatar
How much voltage do you have across it?
Old 10th February 2010, 08:42 AM   #26
I have 6mV and 5mV on the other channel.
Another thing, I use 1k reistors on R6/R7 instead of the suggested 270R (http://www.audiosector.com/lm4780%20amp.pdf) because nationals PDF suggested it, if that have something to do with it (I dont think it should?).
Old 10th February 2010, 11:06 AM   #27
danielwritesbac's Avatar
Originally Posted by Tomten View Post
When I measure directly from input to the chassis ground I get 22k, shouldn't that mean that the resistor does its job?
If the DC coupled amplifier has insufficient input load (at DC), then it will make offset.
Problem:
The spec is 22k resistor paralleled with 20k pot. So, if half the load is missing or if there's a capacitor in-between (problem if half the load is missing for DC) then offset is high.
Symptom: The amplifier acts like the potentiometer is missing.
Patch: You can use 12k instead of your 22k input load (R0/R4). This is a load at (upon) DC. It compensates for a missing potentiometer.
-or-
Patch: You can move your input filter cap from between the amp and pot, then re-install this cap between pot and rca jack. This repairs "cap in the wrong place" problem, and it also provides protection for the potentiometer.
Old 10th February 2010, 11:24 AM   #28
Why mix two different designs at random?
Audiosector design:
Maximum value appears to be 680R.
Since input load is half of feedback value then a more appropriate value appears to be 330R, and so 270R (in the directions that you didn't follow) is close enough.
Old 10th February 2010, 11:29 AM   #29
The 680R is for R3/R5 which i use. Or do you really mean R6/R7?
I dont use a potentiometer, its just a power amplifier. The problem is the huge difference in offset. I was thinking if I made a bad solder on the jumper, that one on the internal chips sees no load (R0) and then makes this high offset, but I cant see any problems on the solder. I have to check it out.
Old 10th February 2010, 11:47 AM   #30
Aha!
Here's some component values for you then.
R0, R4 are 12k for when/if you don't have a potentiometer.
(10k is workable)
R6, R7 are 270R (330R is workable)
A too-high value of R6, R7 will increase DC offset with that particular amplifier board.
High Dc Offset Issues nic6paul Class D 2 3rd March 2009 02:49 PM
Question about DC offset from source. theAnonymous1 Solid State 2 12th November 2006 08:07 PM
BrianT LM4780 DC offset SEIJI Chip Amps 8 21st April 2005 02:23 AM
36 V DC offset when source connected revell Chip Amps 12 27th February 2005 08:29 PM
High DC-Offset - Why? rampage101 Chip Amps 1 30th April 2004 09:16 AM
Page generated in 0.10587 seconds (82.60% PHP - 17.40% MySQL) with 11 queries
