Old 1st February 2010, 02:27 AM   #1
Default 2nd stage amp.
hi I know its been done, as the best sounding opamp, but I have 2 specific q's please.
1/ best single op amp for a first stage 100 ohm load ( noise) amp with about 50db gain
currently using lt1028, but is there better sounding given coinstraints.
18 volt _/+ rails
I can check feedback R's if need be.
2/ following on we have passive riaa stage so loading requirements, I can check values if need be
and a dual opamp with a bit of make up gain, I think its bog std. 5532 here.
so how do I better the 5532 with
1/ a conventional dual and
2/ with an adaptor praps?
thanks for help
Old 4th February 2010, 02:59 PM   #2
bump still wondering....
Old 4th February 2010, 04:09 PM   #3
Iain McNeill's Avatar
This is for a phono input stage right?
Douglas Self has written comprehensively on the subject and has a great website. If you can post some more info e.g. impedance of your cartridge & output level I'm sure there's a lot of knowledge on the forum.
You've searched on the subject here right?
urgent ! 2nd class A amp enclosure GP jrsun Swap Meet 52 21st April 2011 11:56 PM
2nd Order Crossover & Phase… dynoPort Multi-Way 8 15th June 2007 10:15 AM
2nd LM4780 BASED AMP COMPLETED-PICS* Dominick22 Chip Amps 15 15th July 2006 11:22 PM
Adding a 2nd input to small practice amp nfway Chip Amps 4 20th October 2004 06:53 PM
Page generated in 0.07945 seconds (74.44% PHP - 25.56% MySQL) with 10 queries
