Old 5th February 2010, 03:00 PM   #21
xecluded's Avatar
Originally Posted by gootee View Post
In your picture in post 13, it shows three power inputs, for AC18V/Gnd/AC18V. Those are probably for yellow, black, yellow from your transformer. Those terminals are not shorted together. So they will not short the transformer.
You need both yellow wires, connected as described, in order to have the on-board AC-to-DC power supply develop both positive and negative DC voltages. Without that happening, the circuit will not work correctly.
I will wire all three yellow/black/yellow and keep you update next week. Thanks.
Old 18th February 2010, 10:51 PM   #22
xecluded's Avatar
That did it - the hum went away after I hookup all 3 yellow/black/yellow wires. Thanks all for your help.
does some know how to build a 60hz hum Eliminator which stops the 60 hz hum?? prorms Solid State 21 13th August 2011 07:26 PM
Airpax hum/shielding against hum planarboy Analogue Source 6 9th November 2008 11:30 PM
Help with hum small hum problem... Guiness Tubes / Valves 10 5th May 2003 04:23 PM
hum problem with LM1875 JAZZ2250 Solid State 1 13th February 2003 06:42 PM
Copyright ©1999-2013 diyAudio
