| Chip Amps Amplifiers based on integrated circuits |
Hello,I am new to this forum and very new to electronics.I am trying to learn as much as I can,but I am the type that only after I actually complete a task will I understand it completely.I bought an LM380 kit to build an easy intercom circuit(It says great for a kid or beginner,so I really feel like a moron).The Schematic shows a simple transformer symbol as T1=25:1.The part that is confusing me is the kit does not come with a transformer.The only thing I can figure is I could use one of the potentiometers,which the kit did come with.I know this is probably a simple question to answer,but I have searched the web for two days and can't get a clear answer of whether or not a potentiometer would work or what the difference between a step down transformer and a pot is.Any advice would be helpful.I attached the schematic for this circuit.Thanks in advance.INTERCOM 2(a).jpg
#2 |
Did the kit come with a relay ??
#3 |
It came with 2 Pushbutton, SPST Momentary,switches.It came with many capacitors,resistors,pots,4 transistors.The kit is for a variety of circuits,but I wanted to do the simple intercom first.At least I thought it was going to be simple.Like I said I am very new to circuits.
#4 |
The kit should have come with a transformer unless they have changed it. the 25:1 transformer is there to act as a step-up transformer to allow the speaker to be used as a microphone.
#5 |
It's a real pity these circuits and kits are so hit and miss especially for a beginner.
That transformer is crucial to the design as Jaycee points out... Have you got a link to the kit so we can have a look You ask the difference between a pot and transformer.... well the short answer is they are two totally different things. The pot allows you to "tap" of a voltage along the length of its carbon track using the middle terminal or "wiper. It can never increase the signal level. The transformer can provide a voltage gain... in your case from the tiny voltage the speaker produces as a microphone into something larger that the LM380 can work with... but you don't get something for nothing doing that, but that's another story. |
#6 |
Here is the link to the kit and parts.NightFire Electronic Kits : (#1415) LM380 2.5 Watt Audio Power Amplifier Kit - $8.25 don't know why my last post did not show up,so if this gets posted twice I am sorry.Thanks for the info. so far.I don't feel quite as stupid knowing that I am supposed to have a transformer to complete this.If anyone knows of a link to a simple circuit I can build with these components,I would greatly appreciate it.If not I have seen other schematics of this same intercom except they use a transformer from Radio Shack #273-1380.If I have to I will order this part and complete the Intercom with it and the other components from the kit I bought.
#7 |
This is not a kit as such, just a collection of components which includes a LM380.
No circuit diagrams are supplied with it and there appear to be no recommended projects for it only suggestions. It is up to the buyer to decide on a circuit and obtain those parts which are not supplied. |
#8 |
I'm wondering if a small "Output" type transformer you find commonly would work here
#9 |
Sorry for not replying earlier...
First off it's worth having the data sheets for parts handy, and for ic's these often give applications too... I see where your circuit came from now, http://www.datasheetcatalog.org/data...r/DS006977.PDF Data sheets from LM380 Datasheet pdf - Audio Power Amplifier - National Semiconductor It might be worth experimenting... if you can get an old scrap ancient transistor radio, the old 6 transistor types of 40 years ago lol, these had small trannys in them for matching the speaker to the amp... probably just right for your project. |
#10 | |
| Intercom sound system help | FerisB | Everything Else | 4 | 22nd June 2009 02:20 PM |
| lm380 question | jufreese | Chip Amps | 14 | 15th March 2008 08:16 PM |
| lm380 2watt amp | prorms | Solid State | 3 | 17th August 2006 02:58 AM |
| 2 watt lm380 amp | prorms | Chip Amps | 0 | 17th August 2006 12:47 AM |
| Page generated in 0.11590 seconds (80.83% PHP - 19.17% MySQL) with 11 queries |
