Old 27th January 2010, 07:25 PM   #1
maurycy is offline maurycy  United States
Default How to add source selector to GC
Few years ago I have built LM3875 based GC. Now, I want to put it in a nice case so it can finally make its way to the entertainment center under TV :-)
One modification I would like to do (if it is relatively easy), is to add source selector. Now, since my electronics knowledge is very limited, could somebody point me to schematics or instructions on how to wire source selector?
Also, where to get rotary switch that will server this purpose?
Thanks.
Old 28th January 2010, 04:52 AM   #2
ratza is offline ratza  Romania
ratza's Avatar
Input selector is just a double pole switch, find one having enough positions to fit your needs. The connections are very simple: the cursor goes to amplifier, all the other pins go to inputs (RCA plugs probably). All the grounds go toghether at signal ground.
Any solution is a compromise.
Old 28th January 2010, 05:09 AM   #3
Thanks.
If 3 in. is enough for your need; go with 2 miniature DPDT switch.
Praudio
Old 28th January 2010, 01:10 PM   #4
Thanks for replies. My case is setup for two pots. One would be volume and one source selector. Would something like that work?
4 Pole 3 Position Rotary Switch
Old 28th January 2010, 02:15 PM   #5
ratza's Avatar
Yes, it will work, you can even lift the ground for each RCA. Be careful, as it has three positions, therefore only three inputs can be used.
Old 28th January 2010, 02:26 PM   #6
So if I have set of three input RCAs (total of 6 single RCAs), that switch would work, right? I am kinda lost what the whole 4 pole means. I guess I have to do some reading.
Old 28th January 2010, 03:45 PM   #7
ratza's Avatar
Yes, it fits. 4 poles means that you have 4 different cursors, i.e. 4 signal lines.
Old 28th January 2010, 07:11 PM   #8
audio1st's Avatar
Hope it helps?
Old 28th January 2010, 07:55 PM   #9
Thanks a lot audio1st. Picture is worth 1000 words. I have printed it and now need to buy the switch. Once I have it, the connections should be pretty easy having this diagram.
Old 28th January 2010, 08:36 PM   #10
leadbelly's Avatar
Originally Posted by audio1st View Post
Hope it helps?
That's a terrible way to do it. If you have extra poles on the switch, use them to switch the GROUND connection as well. This way can break ground loops and be noticeably quieter.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Digital source selector? vaughn Digital Line Level 17 22nd August 2010 05:30 AM
source selector mnr102 Multi-Way 0 24th February 2008 11:11 PM
Any good source selector? MGH Parts 6 12th April 2006 08:40 PM
Here's a source selector DragonMaster Everything Else 0 7th August 2005 03:52 AM
How to add a high / lowpass to an IGC / GC? Cradle22 Chip Amps 27 8th December 2003 09:31 AM
Page generated in 0.10597 seconds (80.15% PHP - 19.85% MySQL) with 11 queries
