Beginner's Gainclone guide
Old 23rd June 2003, 05:29 AM   #41
gchrist is offline gchrist
Default Regulated power supply
Why is the power supply for the Gainclone not regulated? If it was regulated would the performance be better?
Thank you
George
Old 23rd June 2003, 10:25 PM   #42
ukram is offline ukram  Finland
The LM3875 has 120 dB supply noise rejection. According to my measurement with RMAA and soundcard, inverting gainklone has 82 dB S/N ratio, so regulating supply voltages does not make sense, as long as there is enough voltage to drive the speakers.
Old 23rd June 2003, 11:04 PM   #43
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Default Re: Regulated power supply
Fred built one, and his results are here.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 24th June 2003, 04:26 PM   #44
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
I still dun get it...does the amp need positive negative supplies?? like +-30V ?? I'm sorry but the tranny wiring picture is down....one myside at least..wonder why??
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 30th June 2003, 01:51 AM   #45
alvinlim is offline alvinlim  Malaysia
Default Grounding scheme
Hi...
I am kind of confused on the grounding scheme. I understand the need for both star and power grounds. In the schematics, the power ground is connected to the DC 0V "G" which is correct.
Do I need to connect the Power Ground (PG) to "Earth" (the mains earth wire). In the beginners guide, it mentioned that we should connect the PG to earth via a 100 Ohm resistor and a 0.22microf capacitor. Why do we need that?
Alvin
Old 1st July 2003, 07:45 AM   #46
Default speculation
just a guess - is the resistor to make cure that the P(G) is always positive with regards to the earth?
Beginner's Gainclone guideHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
