| Chip Amps Amplifiers based on integrated circuits |
Can anyone suggest a part number for a stereo amp that will deliver 10 - 15 watts (for a PC amp), commonly available.
I want to use a standard 12v 2A wall transformer and get that up to 14v or so with a bridge. Most bang for the buck? No class D nonsense -- good ole AB. |
#2 |
phillips TDA1558Q is good in term of simplicity/perfs..
the 4 amps for a stereo bridge are in one case, and the number of external components is surprisingly low... |
#3 |
surprisingly low is right -- a few caps and the speakers.
thanks. not recommended for new designs only drawback. |
#4 |
#5 | |
It works from 8V to 28V. The maximum output @ 0.1% distortion is 3.5W into 8r0 from +24Vdc and 2.5W into 8r0 from 18Vdc. From 14Vdc the output will be even lower. You either need more supply voltage or a different style of amplification to get 10W to 15W into 8r0.
regards Andrew T. |
#6 |
12V and 2A power supply means 24W available, and maximum half of it can be the output power of the amplifier (in class AB). 2x6W that is.
Any solution is a compromise. |
#7 |
15W into 8r0 requires ~11Vac to the speaker.
This can only be achieved from ClassAB with a PSU of >=33Vdc. It can be single polarity 34V or dual polarity +-17Vdc.
regards Andrew T. |
#8 |
#9 |
he asked for ClassAB
not for a pair of bridged AB
regards Andrew T. |
#10 |
| silicon chip magazine 15w class a amp | jamesfeline | Solid State | 24 | 24th May 2007 12:01 PM |
| Is it Chip or BJT in this Stereo Amp? | boxedin | Solid State | 4 | 25th December 2005 02:44 PM |
| Stereo Chip Amp - one transformer or 2? | groyne | Chip Amps | 12 | 18th May 2004 06:22 PM |
| Page generated in 0.09823 seconds (78.31% PHP - 21.69% MySQL) with 10 queries |
