Old 4th July 2011, 10:24 PM   #71
Here's what I use in my actice 3-way system.
Mike
Old 4th July 2011, 10:52 PM   #72
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
That's interesting Mike, thanks. I don't think I've seen anything like that before. Is that basically a buffer inside of the feedback loop for the first stage? One thing I really don't get is the 49.9R basically jumpering the buffer stage.
AJ
Old 4th July 2011, 11:35 PM   #73
jcx is offline jcx  United States
two 50 Ohm esistors are making sure the output current divides equally between the 2 op amps - a way of doubling the output current
I'd use a genuinely high output current op amp in a multiloop composite
CFA op amps designed for A/DSL line driving make excellent outputs for audio line levels
Old 4th July 2011, 11:39 PM   #74
Hi Stormrider,
Yes, it's kind of a "poor man's" buffer. I needed a little more current drive capability for the three active filter inputs than a single LM4562 could deliver and didn't want to mess with a separate buffer chip or discretes, plus there are already two Opamps right there in the chip ready to use. The 49.9 ohm resistors are there to equalize the output currents from each chip so they won't "see" each other's outputs, and because they're both in the feedback loop, only penalty is slightly reduced output voltage. It works really well, sounds good.
Mike
Old 4th July 2011, 11:58 PM   #75
Cool. Like I said I've never seen anything like that, but then I've only been at it for a few years now.
The DRV134 has more than enough drive capability for what I need, so I'm good with the circuit I'm working with now. They are kind of expensive though, ~5$ea at mouser, but not bad compared to signal transformers.
AJ
Old 6th July 2011, 12:45 AM   #76
Come on guys, this has got to be far from an ideal design. I know there is room for improvement. I'm open to ideas.
AJ
Old 6th July 2011, 12:58 AM   #77
What do you consider "ideal", what are you trying to accomplish?
Mike
can I use this transformer to power the opamp based preamp? zome Parts 3 16th June 2009 11:27 PM
A couple basic questions on opamp I/V NeoY2k Digital Source 6 13th November 2008 11:55 AM
Considerations about opamp based preamp Tolu Solid State 10 12th September 2008 01:10 PM
Yet another Opamp based regulator banana Power Supplies 4 22nd January 2007 02:46 AM
Opamp based preamp, for a gainclone Bricolo Solid State 5 9th March 2003 05:36 PM
Page generated in 0.08650 seconds (74.34% PHP - 25.66% MySQL) with 11 queries
