| Chip Amps Amplifiers based on integrated circuits |
#11 |
Any particular reason for driving the volume pot with an opamp? I just recently made a simple opamp-based preamp myself with a 100k log volume pot followed by a 100k balance pot followed by a single gain stage and it seems to work just fine. The dc-offset does vary with the volume and balance settings, but I dealt with that and other DC-offset sources using a DC-servo loop. Opamps I used were LME49720 for the gain and LF412 for the servo.
#12 | |
Sorry to post Rod's image, but this is the balanced line driver I'm going to use. It's from P51.
AJ |
#13 |
AJ |
#14 | |
Maybe the DC offset is not so much a problem for you if you only have a gain factor of two. Also, regarding the order of the stages: I'd put the gain stage first, if possible. That way you avoid amplifying noise from the previous stages. (I learned that the hard way too.) Last edited by Corben; 18th January 2010 at 08:20 PM. |
#15 |
Just did some testing with the 2nd circuit shown with an NE5532P from Texas Instruments. Output offset varied from +3mVdc to -27mVdc with turning the vol control pot from min to max. Most of the offset is coming from the buffer; there's -20mvdc on pin 1.
I then dropped in a TL072 and output offset dropped to .1mVdc - .8mVdc. depending on where the vol control was. Big difference with the fet opamps for a direct coupled circuit.
AJ |
#16 | |
G² |
#17 |
#18 | ||
If I drop R2, the 100K, down to 22K the dc offset on pin 1 drops to ~5mVdc but that will make my input impedance way too low.
AJ Last edited by Stormrider; 19th January 2010 at 12:06 AM. |
#19 |
Just realized R2 is on the wrong side of R1. That has no effect on the offset though.
AJ |
#20 |
R4 should be equal to the impedance "seen" by the inverting input of the op-amp. I.e. R4 = R5||Rf. For your values of 10k, 22k, R4 works out to 6.88 kOhm. 6.8k is probably close enough. Similarly, you could insert a 1k from pin 1 to pin 2 of U1A and compensate for its input bias current. This won't change the gain.
I don't see a purpose for R3. Unless you like adding thermal noise, I suggest taking it out. I would put the amplifying stage before the volume control to avoid attenuating before amplifying. It'll be better for the noise performance, though, in your case with a 3 dB gain, you probably won't notice the difference. I suggest bandwidth limiting the first stage. I'd set a pole there at about 200 kHz. So C =1/(2*pi*1000*200E3) = 795 pF. I'd probably use 820 pF as this is a standard value. Or 680 pF... It'll limit clicks and pops that you otherwise would get every time an appliance or other heavy energy-sucker turns on. It'll also limit EMI from your cell phone and WiFi devices. Good circuit, though. I suggest using an LME49720. Those amps are superb. My preamp is a design similar to yours (with the changes I suggest above) except I use a PGA2310 volume control IC. ~Tom |
| can I use this transformer to power the opamp based preamp? | zome | Parts | 3 | 17th June 2009 12:27 AM |
| A couple basic questions on opamp I/V | NeoY2k | Digital Source | 6 | 13th November 2008 12:55 PM |
| Considerations about opamp based preamp | Tolu | Solid State | 10 | 12th September 2008 02:10 PM |
| Yet another Opamp based regulator | banana | Power Supplies | 4 | 22nd January 2007 03:46 AM |
| Opamp based preamp, for a gainclone | Bricolo | Solid State | 5 | 9th March 2003 06:36 PM |
| Page generated in 0.84472 seconds (13.47% PHP - 86.53% MySQL) with 11 queries |
