Old 18th January 2010, 01:45 PM   #1
Default Simple Class-A Chipamp
i am just finished my Chipamp project and one of mycolleague in this hobby introduced his design, which i build also last week.
There is no caps in signal path!
I am interesting about your opinion about this concept.
This kind of design should deliver Class-A quality depending on OPA?
Br
Attila
Old 18th January 2010, 02:58 PM   #2
analog_sa's Avatar
Do you think TL082 works in class A?
Old 18th January 2010, 07:00 PM   #3
Of course not. The buffer transistor works in class-a due to bottom current generator transistor.
Old 18th January 2010, 07:22 PM   #4
analog_sa's Avatar
Therefore it is a simple chipamp, but not class A. Unless you bias the opamp in class A as well.
Old 18th January 2010, 07:24 PM   #5
wahab is offline wahab  Algeria
an opamp is biaised in class a, providing the
output current pumped by the load is significantly
less than the current consumed by the opamp..
Old 18th January 2010, 07:30 PM   #6
analog_sa's Avatar
Sadly i don't know the quiescent current of TL082, nor the beta of the transistors. That's why i asked.
Old 18th January 2010, 07:37 PM   #7
That 4.7k resistor is not a good way to bias the output transistor curent source.
Old 18th January 2010, 07:41 PM   #8
1.4 mA...that s not a lot, and considering that part
of this current is used for internal biaisings, it does left
no more than a few hundreds uA to feed the transistors bases
and still retain class A in the aop output stage..
if you have no need of very high input impedance, you can use
a NE5532 which have a quiescent current of 8 mA, and thus, should be capable of
roviding a few mA in class A mode...
Old 18th January 2010, 08:51 PM   #9
Juergen Knoop's Avatar
the opamps output-stage runs always in 'class' A, regardless of its quiescent current etc. Its upper transistor never shuts of because it must always supply a positive current to the discrete stage.
regards
Old 18th January 2010, 08:57 PM   #10
regards
not at all..
NE5532 is given at 8 mA quiescent current, yet can provide
almost 40 mA to the load...
you can be sure that at more than 8 mA output current,
the output stage is in class B mode..
Class A gainclone/chipamp idea Steven Chip Amps 21 21st December 2011 01:52 PM
Simple question regarding converting chipamp from 110V to 220V maurycy Chip Amps 16 8th December 2008 11:58 PM
Hum to noise problem with class A chipamp ionomolo Chip Amps 5 2nd June 2008 03:48 PM
The Super-Simple ChipAmp, Pt. II Spasticteapot Chip Amps 4 5th November 2006 11:43 PM
Simple/Cheap computer speaker chipamp Mr Teal Chip Amps 4 9th May 2005 09:32 PM
Page generated in 0.10709 seconds (79.41% PHP - 20.59% MySQL) with 11 queries
