| Chip Amps Amplifiers based on integrated circuits |
hi guys,
please check my one sided LM3875 pcb layout, thanks schematic is from NS non inverted |
#2 |
could you number the component locations and post the schematic with matching numbers.
regards Andrew T. |
#3 |
Here it is
#4 |
Location: On a hill, in a wooden shack, next to the woods, in Somerset.
Hi Bedi
It appears that it will work, from not too close scrutiny late at night. But I think the layout could be improved a fair bit. I would try to keep the power side away from the signal side, and since you don't appear to be concerned about where the heat sink is going I would put all the power components on the back and the small signal components on the front. And get those capacitors close to the chip. Personally I would run twisted wires to the base of the chip and put the caps just outside those. Have them come down vertically onto the board if possible or, if horizontal, from directly behind - maybe even going underneath the caps. I'd then have the output coming out on the same side, leaving the front clear for low level signals. For these I'd have two tracks coming straight out, with the resistors a bit further away. Then you can have your feedback resistor going across from pin to pin. almost right under the chip. Also , the last thing you want is your loudspeaker cable going right past your feedback resistor. I think there is a MISTAKE here. R2 should be after the 220R. It will still work but you won't get your 22k loading. One other thing, do you really need the gain to be so high. Most power amps are around x 20 (26dB) and you have chosen x33. If you need it then fine, but the distortion will be higher because you will have lost bandwidth and the feedback won't be doing its best. These chips can sound grainy at times and one shouldn't encourage it. If you discover you really don't need the gain then it might be worth changing R3 from 680R to 1k1 or a bit above. You may hear a striking difference. Good luck. (Check your pins, because I haven't) All the best Christian |
#5 |
you have omitted the decoupling caps and the RF filter you have adopted a DC coupled design and signal ground is connected direct to power ground.
This all invites disaster.
regards Andrew T. |
#6 |
But I have a pair of amplifiers in these plates, and everything works.Why disaster? DC offset is 35mV (when input signal is open to 200mV). Of course,I would like to do best, but only on single sided PCB.BrianGT made a great double sided PCB, but is it possible to do the same thing on single sided PCB? Any suggestions
regards, Bedi |
| lm3886 single sided pcb | ryan750 | Chip Amps | 20 | 30th March 2012 04:11 AM |
| lm3875 single sided pcb layout | SolderN | Chip Amps | 18 | 12th August 2009 10:11 PM |
| Single Sided LM3875 PCB... Crit please. | justblair | Chip Amps | 15 | 8th July 2007 10:52 PM |
| Help needed for LM3875 design + simple single-sided PCB. | Spasticteapot | Chip Amps | 12 | 2nd April 2006 07:25 PM |
| Single sided PCb for lm4780 | rs1026 | Chip Amps | 11 | 22nd August 2004 09:16 PM |
| Page generated in 0.07523 seconds (77.77% PHP - 22.23% MySQL) with 11 queries |
