Old 15th January 2010, 07:40 PM   #1
Default lm1875 problems?
Hey all- new to this forum and new to building chip amps,(up till now all tube), running into a problem with my lm1875 it powers up and sounds great for 2 min, and then fizzes out ,if I turn it off wait a minute and turn it on it does the same thing any ideas?
Old 15th January 2010, 09:55 PM   #2
mjf is offline mjf  Austria
hello.
does it run hot?
greets..........
Old 16th January 2010, 12:58 AM   #3
Its not hot to the touch, Im using a bipolar power supply at about 14v, does the heatsink need to be grounded?
Old 16th January 2010, 01:50 AM   #4
Speakerholic
Cal Weldon's Avatar
Moved to chip amps. Troubleshooting is for concerns with the forum.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 16th January 2010, 12:26 PM   #5
precisely, tell us how you have coupled the chipamp to the heatsink and tell us the rating of the heatsink and whether it is exposed to ambient air or stuffed inside a shoebox.
A few pics might help.
regards Andrew T.
Old 16th January 2010, 01:41 PM   #6
its bolted with a mica washer to a heatsink that was in a marshall amp ,wich was using a tda2050,there is a little heatsink grease on it its in the open air ,I dont have a preamp connected just trying to get the power amp up and running thanks
Old 16th January 2010, 04:18 PM   #7
got it figuired out, thewire from pin4 to 1 ohm resister was about 6 inches long ,I put the resistor right on the pin and ,she purrs like a kitten ,thanks for all the info on this site!
Suggestion for LM1875 makarand_g Chip Amps 13 7th April 2008 07:24 PM
LM1875 slewrate f.sessink Chip Amps 1 30th October 2007 08:34 PM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 03:28 AM
LM1875 schematic... w00t Chip Amps 7 20th December 2004 02:56 PM
Lm1875 soundNERD Chip Amps 14 12th October 2003 02:26 AM
Page generated in 0.07695 seconds (74.69% PHP - 25.31% MySQL) with 10 queries
