Old 15th January 2010, 10:10 AM   #1
Default TDA7293 circuit = half wave rectifier
Why?
HTML Code:
<a href="http://s235.photobucket.com/albums/ee61/myspaceblogphotobucket/?action=view&current=TDA7293circuitcopy.jpg" target="_blank"><img src="http://i235.photobucket.com/albums/ee61/myspaceblogphotobucket/TDA7293circuitcopy.jpg" border="0" alt="Photobucket"></a>
I know the power supply is anemic. I can fix that. I'm new to this stuff. Anybody?? anything??
help!
Old 15th January 2010, 10:30 PM   #2
Well, that link doesn't do anything. Lets try something else!Click the image to open in full size.
Old 16th January 2010, 05:42 PM   #3
A voltage doubler ,to get V+ and V- from a single supply.A split supply would be better for a power amplifier.
xxx I should correct my spelling xxx
Old 16th January 2010, 11:10 PM   #4
Ok....that pic doesn' load either. Try again?
See if this works!
Old 17th January 2010, 11:31 AM   #5
Hi booj
What is it you are asking,could you be more specific.
I can see my answer wasn't very clear either.What you are referring as "half wave rectifier" is called a voltage doubler or voltage multiplier.In this PSU it is used to get V+,V- and GND from a transformer with only two leads.Better solution for a power amplifier is to use acenter tapped transformer or two transformers.there are several ways to do it as you may already know.
Old 17th January 2010, 11:40 AM   #6
jaycee is offline jaycee  United Kingdom
The power supply is silly - it produces +12V and -12V, but at the kind of current a power amp will use it will have excessive ripple.
The configuration of the TDA7293 itself doesnt make any sense either. The best thing to do is read the datasheet - it has a few good example circuits (and pcb layouts, double sided though) that you could use.
Old 17th January 2010, 10:06 PM   #7
Thanks so much for your replys. I'm sorry that my circuit is so crappy! It's just a quick throw together type breadboard circuit that I thought should have worked at least enough to improve on.
The reason I don't follow the spec sheet is because although it shows a circuit with all the parts it has the standby and mute going off somewhere with some vague reference to going to V+ through a resistor. Does it or don't it?
And the clip detector goes to Vclip. So what's that?
Guess I should have started with the thread and then built the circuit. I was trying to sort of copy a Marshall AVT50 circuit, which uses a TDA7293 in the output stage. That file is too big to download here. So's the spec sheet on the chip.
If anybody cold help me with the Vclip and the mute and standby things I'd probably be set. The datasheet is easy to Google
Old 18th January 2010, 12:18 AM   #8
Minion is offline Minion  Canada
Actually the TDA7293 datasheet has a single sided single channel PCB that is useable , I built an amp with it and it worked fine , I suggest you try it ......
a Voltage doubler is whoefully inadequate for a Power amp expecially with the currect demands of a TDA7293 which will probably sag the supply down to +/-10v with lots of ripple ..... I used a 200Va 2 x 28v Transformer for a single channel with 10,000uF per rail and 1000uF at the chip .....
PS: You don"t need to use the clip detector , the Mute feature needs most of those parts to eliminate the turn on thump , it can simply be connected to the positive power rail through a resistor (10K should work) so no seperate 5v supply is needed .....
I also used a TDA7293 to build a Guitar amp (a 100w head) with a tube preamp , sounds great ....
Old 18th January 2010, 08:51 AM   #9
Hey Minion,
Is the scat you use exactly the same? I noticed you said a 10 k instead of a 22 k would work fine for getting out of turn on pop. Any other changes?
Also, I'm not trying to get the max power from the chip. I want 30 watts max. Maybe less. I want a "blowproof" design.
As far as the power supply is concerned, what do you do when the ONLY thing you've got is a 12 volt tranny? Huh? Scuse me!
Dude(s)! I can buy a tranny! I can do this! BUT.... I am ignorant to the point of nausea about these circuits! I need help.
So here I am, and this is the latest sketch.
I think I need a 10 ohm is series with a .22uf to ground on the output. Any other suggestions?
Thanks again guys
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
Full wave or half wave rectification help! HaLo6 Digital Line Level 1 26th March 2009 01:14 AM
half wave rectifier will not saturate transformer core? vax9000 Tubes / Valves 1 2nd November 2006 03:33 AM
Half wave horn project. bobhayes Full Range 19 7th December 2005 03:06 AM
35Z5GT half-wave rectifier Isaac Teller Tubes / Valves 8 15th October 2004 05:26 AM
Page generated in 0.10025 seconds (81.97% PHP - 18.03% MySQL) with 11 queries
