| Chip Amps Amplifiers based on integrated circuits |
#91 | |
but perhaps that rather to costly ship this IC from the us to france, it would wonderfully fit for a kid, as a guitar amplifier, who knows, you surely know one... as pointed by daniel, it has a high gain, as 50 mV rms are enough to reach full output, so it fill perfectly this purpose.. surely that it was done for automotive radio k7, as the magnetic head has trouble giving 1 mV output, a hard task for the following premaplifier, usually a dual opamp, so a part of the necessary gain was reported on the power amplifier, not counting that the FM circuits has also low ouput level, no more than 100 mV... well, next time, i ll stick to the choice of the majority, (among 3 !!) , and go for the 8561Q... |
#92 | |
We'll find out more about it soon. Still awaiting the mailbox. . .If that doesn't work, then a good "Plan C" could be TDA1554Q, because those probably have a good tone, low heat, and reasonable gain. Also, pin 15 on that chip is supposedly n/c like pin 9, and non-connected pins can be joined with the ground very, very conveniently. For the bridge mode amp, this could shield the input pins nicely. Okay, this was such a cool idea that I bought one of these too. Now a have a wealth of little amplifiers and less real money. ![]() Maybe irishpatrick33 can give me a lesson on how to turn audio back into cash.
#93 | |
#94 | |
Right now I only have two things for sale: RCA connectors and speaker input plate cups. |
#95 | |
I just take whatever I don't want and throw it on Ebay. Though I've also used Audiogon to sell a pair of Manley Mahi monoblocks and some tubes. I just start an Ebay auction for a penny and that seems to drum up interest. Any time you use a fixed price, interest is minimal and slow to sell unless cheaply priced. |
#96 |
In the mailbox, there were TDA1554Q amplifiers. The newer model TDA8561Q has not yet arrived.
I'll be building them up when both models arrive, and will report back with some observations. Its "highly likely" that there is sufficient gain this way: 12vdc MP3 player However, I'll be checking to see if this combination has sufficient gain to reach full potential (of the more powerful amplifier). 15vdc MP3 player |
#97 | |
#98 |
Probably Mouser, Digikey, Ebay, Allied. . . will have some availability.
11W could be rather under-whelming in comparison to the ongoing experiments with the Philips chips. Distortion becomes important in direct proportion to the amount of amplification. Proportionately, 1% of almost nothing is really almost nothing; however, 1% of 70w is a bit too much distortion. For this project, the distortion relates to the gain setting, actually. If the gain is set needlessly high, then the noise floor (distortion) is also needlessly high. That's exactly why the upcoming redo is for a lower gain amplifier, with a "sufficient" amount of gain, but not more. |
#99 |
TDA1554Q works appropriately, and is recommendable for a fun little project.
It runs surprisingly cool (hyper-efficient) and gives a nice size presentation. There's not audible noise while its running. It appears to use a 20k pot (dual gang potentiometer for volume control). This amp doesn't exceed the quality of a T-amp, and it is exactly as sensitive to power circuit and power cap quality. The amount of gain is just about perfect for MP3 player and PC. This amp isn't as powerful as TDA1558Q, but the difference is minor, and was expected. I had to use that 15v econo replacement laptop cord to get as much power with TDA1554Q as TDA1558Q can do with 12v; however, there's a good reason for it. . . Oddly enough, TDA1554Q has MUCH more bass, and the power difference could probably be corrected by choosing smaller size input caps. On these small scale amplifiers, there's no need to pass deeper bass than your speakers can reproduce--12" woofers, corresponding to 0.47uF input caps at the amp's input, with smaller woofers using smaller capacitance for efficiency. Excellent news: The "uncompress" effect is present, similar to TDA1558Q; however, TDA1554Q plays more cleanly. Soon, we'll see what TDA8561Q will do. Last edited by danielwritesbac; 19th February 2010 at 05:50 AM. |
#100 | |
being too low in the 1558Q schematic from phillips. personally, i did double the value, although, as you mention it, it s somewhat useless considering the kind of speakers that are used with it.. just waiting for your 8561Q investigations, i m dead curious about it. Hope it will be successful, as this chip seems to be a good replacement of its helder brother... |
| Difficulties with DC/DC converter 12V to +/-40V, 8 amps | vena2a | Power Supplies | 16 | Yesterday 01:35 PM |
| to convert a 12v dc car adapter to support 19 volts dc | shadiedog87 | Power Supplies | 6 | 31st October 2007 07:27 PM |
| DC/DC 12V-15V inducterless Transformer Circuit needed | Tempest_au | Power Supplies | 6 | 22nd May 2007 12:37 PM |
| 12V-220V(ac) to 12V-50V(dc) | raszvan | Car Audio | 0 | 16th June 2005 08:28 AM |
| DC-DC converter to get +-12V to feed the ouput opamps in DAC2000 | Ryssen | Digital Source | 12 | 22nd January 2004 05:04 PM |
