Old 11th January 2010, 05:50 PM   #1
gary h is offline gary h  United States
Default rectifier help please
hi all,
perhaps someone would double check my thinking on this:
I'm building 8 of PD's chip amps for an active crossover. I have 3 transformers. 2 smaller ones (120VA) have dual primary and secondary and fit well with the rec board. I'll use these for the tweeter and mid pairs.
I also have a 400VA transformer for the 4 bass drivers which each get their own chipamp. The transformer has 6 pairs of primary windings (100-10-10) to make dual 120 primaries, but it has a single pair of 10 gauge secondary wires supplying +/- 21V.
My question is: Should I divide the secondary into dual leads to use with the dual secondary rec board? I think I remember reading PD advising against this but I'm not sure. Will just 4 MUR860s be plenty enough to rectify a theoretical peak of almost 20 Amps? (the data sheet claims 8 A average current, 16 A with repeating load, and 100 peak/ each.) If splitting the secondary is advised, would this require some sort of RC divider?
Thanks for the help,
gary
Old 11th January 2010, 07:34 PM   #2
A single secondary on the 400VA transformer can only give a dual polarity supply if each polarity is half wave rectified.
Don't do this for a power amp.
Buy the proper dual secondary transformer.
regards Andrew T.
Old 11th January 2010, 08:51 PM   #3
Thanks Andrew.
I'd like to understand this better, is this because a halfwave rectification requires a lot more filtering? What does this do to the transformer?
I'll order the new transformers. Anyone need a 25 lb donut shaped paperweight?
gary
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 12:12 AM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
6CJ3 rectifier or 6D22S rectifier 56oval Tubes / Valves 10 19th April 2007 09:48 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Page generated in 0.06658 seconds (73.84% PHP - 26.16% MySQL) with 10 queries
