| Chip Amps Amplifiers based on integrated circuits |
Hallo,
I am a newbie in diy elektronics, but I want to make a lm1875 amplifier. I've found several pcb layouts for the gainclone circuit, but they aren't in black and white, so I can't use them with out modification. Does anyone has a pcb layout? It would make it a lot easier for me. ps. I've found this one: http://i239.photobucket.com/albums/f...Layout1875.jpg but it's not as minimalistic as the gainclone circuit. I don't like the elco in the signal pad. (I don't know what the effect will be on the audio quality) Regards, Stefan |
#2 |
make sure you adopt an AC coupled schematic that has RF filter on the input and Zobel load at the output.
regards Andrew T. |
#3 |
See if these suit your needs.
Any solution is a compromise. |
#4 |
[QUOTE=Arend;2043180]Hallo,
I am a newbie in diy elektronics, but I want to make a lm1875 amplifier. I've found several pcb layouts for the gainclone circuit, but they aren't in black and white, so I can't use them with out modification. Does anyone has a pcb layout? It would make it a lot easier for me. ps. I've found this one: http://i239.photobucket.com/albums/f...Layout1875.jpg but it's not as minimalistic as the gainclone circuit. I don't like the elco in the signal pad. (I don't know what the effect will be on the audio quality) Regards, It look like this circuit'PCB, Lots of guys do it . It was said very good. You can also try 2, 3circuit,It was said the third is the best.The second is better than the firist circuit. I use the samplest. |
#5 |
look at this Beginner's Gainclone, HiFi LM1875, The Amplifier Board think it's the same,he explain it very claer,Sorry for my poor English,maybe you don't unerstand what i said
.and the otrer two circuit without pcb. Last edited by 91art; 11th January 2010 at 02:17 PM. |
#6 |
Thank you very much!
No problem with your english 91art, (I'm also not a native speaker myself) I'm gonna use the pcb from ratza. |
#7 |
Ratza's PCB needs the power ground to pass up between the decoupling capacitors. The long Power ground traces that tie in the caps adds too much inductance to let the little 100nF caps do any good.
The signal ground should be separate from the power ground. Leave a pair of pads to connect the signal ground to the ground terminal by a copper link wire or a 10r resistor and a pair of inverse parallel diodes. Look at the Power ground and the Signal ground in post4 middle pic for ideas.
regards Andrew T. Last edited by AndrewT; 11th January 2010 at 07:31 PM. |
#8 |
AndrewT, you're right regarding traces' inductances. Yet the amp is mute. I just wanted a very compact board in THD technology.
#9 |
#10 |
mravlca,
The schematic is from the lm1875 datasheet, the one with the symmetric power supply. |
| Please check my LM1875 PCB layout | Dominique | Chip Amps | 27 | 15th January 2009 04:36 PM |
| Feedback on Gainclone PCB layout Wanted | maria_andersson | Chip Amps | 29 | 28th September 2005 11:03 PM |
| LM1875 PCB Layout | mangrovejack | Chip Amps | 23 | 25th July 2005 10:03 PM |
| Need LM1875 PCB layout !! | thomgun_lc | Chip Amps | 9 | 10th May 2005 11:35 AM |
| Page generated in 0.10672 seconds (81.14% PHP - 18.86% MySQL) with 11 queries |
