| Chip Amps Amplifiers based on integrated circuits |
Couple of Questions about PC power supply, I have a 350 watt ATX PSU.
Can I use this power supply to test a lm4780 amp to see if its working ok. ie, wire +12v and -12v into amp without using rectifier board. Can I use the power supply to actualy run a small amp (not my 4780), but maybe a chip that will run on 12v. |
#2 |
ATX PSUs are switch-mode, aka very noisy. Also, the -12v rail is going to have much less current then the +12v. Something like 5 amps for the +12v but only 0.5 amps for -12v. Some PSUs will have current per-rail written on a sticker somewhere. If not, Google it or measure it.
#3 |
The negative supply is probably limited to a very low power rating compared with the positive 12V supply. Be careful to check the spec on the different voltage outputs you want to use.
| linear pc power supply? | cowanrg | Power Supplies | 41 | 25th February 2009 02:46 PM |
| At Pc Power Supply Conversion??. | Marvellous | Power Supplies | 4 | 15th March 2007 11:04 PM |
| PC Power supply | MaXiZ | Power Supplies | 26 | 31st December 2005 03:50 PM |
| PC power supply for ZEN4 | Anorgan | Pass Labs | 2 | 5th February 2004 01:08 PM |
| Page generated in 0.06294 seconds (71.54% PHP - 28.46% MySQL) with 10 queries |
