Old 3rd January 2010, 08:50 PM   #1
Send a message via MSN to pyromaniac_
Default using two transformers
I'm thinking of powering two LM1876 chips with two transformers (both at 24 V 60 VA). So, do I have to use two powersupplies then (one for each trafo and chip), or can I just wire the trafos in parallell and then connect them to the same powersupply? I'm also thinking of using a regulated powersupply btw.
Old 3rd January 2010, 09:50 PM   #2
two transformers may have slightly different turns on them. They cannot be paralleled without some form of power wasting balancing.
You need twin secondaries to produce a dual polarity supply for a dual polarity chipamp.
Use each 24Vac transformer to produce a 34Vdc supply. Connect these two supplies in series and you have a 120VA +-34Vdc supply for your 8ohm loaded chipamp.
regards Andrew T.
Old 4th January 2010, 12:28 AM   #3
The transformers are centertapped, so I have to make two separate +-34vdc supplies then, right?
Old 4th January 2010, 12:57 AM   #4
This will work as long as the transformers are the same.
Old 4th January 2010, 09:38 AM   #5
Originally Posted by pyromaniac_ View Post
two transformers (both at 24 v 60 va).
the transformers are centertapped,
tell us what you have.
regards Andrew T.
Old 4th January 2010, 11:45 AM   #6
Ok, I've got: two identical ring-transformers and both secondaries are at 2x24 V and 60 VA. Hope that's clear now.
Guess I can't do as tiltedhalo proposed, since there are two secondary windings at my transformers.
Old 4th January 2010, 12:31 PM   #7
each 24Vac + 24Vac 60VA transformer (dual secondary) is capable of making a 60VA +-34Vdc dual polarity power supply.
Each 60VA power supply is capable of running a 30W to 60W power amplifier.
BTW,
a centre tapped is NOT the same as a dual secondary.
A centre tapped can make a dual polarity supply.
A dual secondary can make two single polarity supplies and can be converted to make a dual polarity supply.
regards Andrew T.
Old 4th January 2010, 01:04 PM   #8
MJL21193's Avatar
His drawing has the transformers wired out of phase:
Old 4th January 2010, 01:24 PM   #9
Attachment 152666
it works as drawn.
Each transformer generates it's own DC voltage and the outputs are connected in series.
Whether the primaries are wired as shown or one of them inverted makes no difference to the operation.
However when leakage current is taken into account you may find that the two transformers prefer the primary connected in either direction. One has to actually test for the reduced/increased leakage of the actual transformer and wire the primary accordingly.
regards Andrew T.
Old 4th January 2010, 01:26 PM   #10
this will work and the transformers do not have to be the same. It still works, you have two independant DC supplies that are isolated from each other and from the mains. Just connect them in series.
regards Andrew T.
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
transformers jaudio Swap Meet 2 18th January 2007 12:01 AM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
transformers then_dude Tubes / Valves 3 3rd June 2004 11:10 PM
transformers Joe912 Chip Amps 8 3rd April 2004 01:34 PM
Page generated in 0.09861 seconds (79.45% PHP - 20.55% MySQL) with 11 queries
