| Chip Amps Amplifiers based on integrated circuits |
I have those at home
what do you think about them. Are the vfet or other transistors. The nr saying that this should be a vfet normaly made by yamaha, but those are made by hitachi. How can I check do those are vfet, is there any way to check it without the datasheet? |
#2 |
Fakes
Looks like Sponge Bob has killed another thread. |
#3 |
#4 |
That's assuming Hitachi manufactured them.
Yamaha and NEC got into VFETs right after Sony started producing amps with the J18/K60. Hitachi developed their Lateral MOSFETs series as an alternative, which was less costly in manufacturing. Main reason why yours are not genuine. Secondly : J26/K76/K77 are Yamaha numbers, no 2 Japanese semi-brands manufacturer identical labelled devices. Thirdly : the uni-style printing on your devices, highly uncommon for the era of devices without manufacturer logo. (Forth : the 5H-6H-7H code lots look like a million dollar sweepstake ticket)
#5 |
It seems fake. 2SK77 must be much larger than 2sk76/2sj26. The package was a mammuth TO-3
Also Hitachi have made Vfets (2sk89-2sj29) if i remember. However by this first simple mode you can check it. With a multimeter on diode (for N devices 2sk76-77) put positive terminal on gate and negative on source or drain: you must measure a pn junction (0,4-0,5V). Then across Drain to Source you must measure a resistance of about 0,5-1,5 Ohm. That is similarly to measure a signal jfets. Francesco |
#6 |
Indeed, and used in amps of Hitachi's subsidiary company Lo-D.
But that was mid-70s, a couple of years before the first Lateral MOSFETs came out, with Lo-D label. The J29/K89 are a good example of how different the Hitachi print looks Half an inch longer than regular TO3s
Looks like Sponge Bob has killed another thread. Last edited by jacco vermeulen; 31st December 2009 at 12:27 PM. |
#7 | |
Then across Drain to Source you must measure a resistance of about 2 Ohm |
#8 |
#9 | |
You must measure the 0,4V pn voltage either among gate to source and among gate to drain. About 2 ohm Resistance you must measure between D-S in either directions. If these are in that way, pheraps they are good. (sure they not are mosfet) To verify these devices in deep you need a circuit with: (Example is for N devices) 1 power supply of about 25-35 Vdc 1 10k Ohm 5-10 W resistor wired from Drain to positive rail 1 1k Ohm 5 W variable resistor wired from source to negative rail. 1 piece of wire from negative rail to gate. It is better if you put device on a heatsink Start with variable resistor to max value. Put a voltmeter at the two ends of 10k resistor. You would read a voltage drop on resistor. If no, then you must diminuish slowly the value of variale resistor on the source. Generally, the N Vfets are going in on state when the Vgs is lower than -15V but is depend on model and rank (-5V at least). Last edited by mos57; 31st December 2009 at 04:59 PM. |
#10 |
ckeck out also this thread:
Oversized TO-3 TO3 like Yamaha 2SK77 and NEC 2D363 - Overview |
| Successors for V-FET SONY-Yamaha-TOKIN 2SJ28, 2SJ18/2SK60, 2SJ26/2SK76 and 2SK180 | tiefbassuebertr | Solid State | 41 | 27th February 2012 04:07 PM |
| 2sk77 | diyman | Solid State | 27 | 29th November 2011 11:28 PM |
| Sony Vfet | housing | Solid State | 3 | 11th April 2009 12:14 PM |
| Sony VFET...tragic... | EchoWars | Solid State | 21 | 11th November 2006 11:40 AM |
| Page generated in 0.10929 seconds (84.21% PHP - 15.79% MySQL) with 11 queries |
