Old 30th December 2009, 03:33 PM   #1
Default Soft start for sub 300 watt units
Im sorry for asking. Ive looked and looked for a simple soft start circuit but all ive found are 20+ component setups and almost need a pcb etched.
Is there something simple i could air wire That could run off of the secondaries or mains?
Old 30th December 2009, 04:20 PM   #2
the safest way is to run a separate supply from a separate 12Vac to 24Vac transformer.
This is switched on and supplies power to the control circuit. A timer, a resistor and/or thermistor and a bypass relay.
regards Andrew T.
Old 30th December 2009, 05:13 PM   #3
MJL21193's Avatar
This is mine:
Doesn't use a separate supply, it uses the positive rail of the supply it works with. About a 1 second delay before the relay shorts the thermistor. Safer than resistor types - the thermistor is capable of carrying the full current even if the relay fails to close.
R6 and R7 value is calculated from the rail voltage and the relay used.
Old 30th December 2009, 08:29 PM   #4
What about this. use 40ohm thermistors at the mains (300 watt load)and put the relay coil across the secondaries with a resistor and diode? a 24vdc coil will trigger at 17-18v. If i put i resistor in line wouldnt it trigger closer to rail voltage?
Old 31st December 2009, 12:15 PM   #5
this is a really bad way to activate/not activate the relay.
The resistor/thermistor will reduce the voltage supplied to the transformer.
This in turn reduces the secondary voltage from the transformer.
In the meantime the rectified voltage has to pass the resistor and the relay.
The relay might pull in or it might not.
Once the relay has pulled in the primary gets the full mains voltage and the relay+ resistor get the full secondary voltage.
If you want to ensure that the relay does not overheat, you take the risk that that a slightly low voltage on the mains may never pull in the relay.
A proper timed delay for the relay control is far better.
regards Andrew T.
Old 31st December 2009, 01:33 PM   #6
PS for just plain and dirty
TDRSOXP-120V
it has 120vac trigger so shouldnt this be all i need period?
Soft Start Necessary? dtaylo3 Class D 2 26th December 2008 09:05 AM
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 01:04 PM
Need a soft start? maxpou Solid State 19 18th April 2007 09:23 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Page generated in 0.09185 seconds (80.92% PHP - 19.08% MySQL) with 11 queries
