Old 29th December 2009, 07:47 PM   #1
stven is offline stven  United States
Default phono input
Does anyone have a suggestion for a simple circuit that can be integrated into a gainclone amp to allow input for a MM phono cartridge? I'd want to share the same power supply (+/- 32.6) and VC.
The cartridge has the following specs:
Recommended Load Impedance (ohms): 47,000
Output: 3.5 (mV at 1 kHz, 5 cm/sec)
thanks
Old 30th December 2009, 01:55 AM   #2
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
i have built a phono stage based on 4*ne5534.i get the schematic from a very old book,year 1992 maybe earlier.it is working good.
the sch file attached.
zang
Old 30th December 2009, 02:06 AM   #3
digi01's Avatar
then you have to use some regulated chip LM7815/LM7915 or LM317 to get a decent +/-15VDC to running the photo stage.
Why balance input for phono amp? Sunsun22 Analogue Source 37 1st December 2009 09:54 AM
6C45 phono input only? mashaffer Tubes / Valves 3 2nd January 2009 12:34 AM
Using phono input with PLLXO mashaffer Subwoofers 0 13th August 2007 11:36 PM
Phono input advice required Satboy Analogue Source 3 24th February 2007 05:02 AM
Phono input usable for other components? camusmuse Analogue Source 21 11th December 2005 09:32 PM
Page generated in 0.07071 seconds (71.97% PHP - 28.03% MySQL) with 11 queries
