| Chip Amps Amplifiers based on integrated circuits |
Hello, I recently sold my Logitech z-2300 and started building a new 2.1 setup for my gaming PC.
So far I have 2 Polk audio monitor 30 that will be ran by a typical LM3886 stereo home made amp. (parts on order) and I would like to add a subwoofer to the setup. What are my best options, to grab a passive subwoofer/enclosure, build my own sub amp? If so which chip amp would be good for a decent little 8" or 10" sub. Another option was to buy a self powered sub such as a Polk 10". Any ideas would be great! |
#2 |
In general a chip amp is not the best choice to drive a subwoofer. It depends of course on the way you use it and your expectations.
You could add the option: grab a passive subwoofer/enclosure and add a plate amp. If you want to build a subwoofer amplifier, you need active filters, A mixer to convert the stereo signal into a mono signal, a phase-shifter, protection circuits, a remote start/stop or automatic signal detector. A plate amp usually has all that on board and for an 8" or 10" woofer you can use the smallest version with something like 80 W or so. Usually they cost less than the components you need to build your own amplifier without all those add-ons.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Thanks for the advice, I actually just remembered that I have a spare Onkyo skw-200 powered sub that I can use meanwhile. Unless the plate amp and "fill in the blank" sub will be a better option. If so, would anyone recommend a decent 8 or 10" sub and plate amp? I would imagine Dayton sub will be suffice with a decent plate amp.
#4 | |
#5 |
Soakin' up the Sound!
About half way down this page is a plate amp. I haven't used one, but I've heard good things about it.
(BTW... no affiliation on my part. Is this a required statement?) NHT drivers and electronics surplus sale Mike
| Grounds concept/direction/advice | angchuck | Chip Amps | 5 | 5th March 2008 04:32 PM |
| I need a quick piece of advice... | ptwining | Class D | 3 | 14th July 2006 12:22 AM |
| need to build a transformer.... point me in right direction? | AudioGeek | Power Supplies | 3 | 5th February 2005 01:37 AM |
| Want to build mono blocks, quick question. | Zemo | Chip Amps | 11 | 21st April 2004 07:48 AM |
| Page generated in 0.07846 seconds (78.61% PHP - 21.39% MySQL) with 10 queries |
