| Chip Amps Amplifiers based on integrated circuits |
#41 | |
Your last statement is probably the key, and actually negates using experiences with any particular amps, and even with multiple amps, to generalize (as if that needs more negating). However, even so, it still might be (and probably is) the case that certain types have certain sounds, typically. Then again, "typical" is often not so great. I guess it might be two completely different discussions and conclusions, depending on whether typical implementations were compared or best-possible implementations were compared. I guess I'll just concede that typical implementations probably do have flaws in common, for each type of amplifier. So it might be more interesting to discuss possible differences between best-possible implementations. But I think that's been more-or-less covered, too, and is probably not really answerable, here, in a practical sense, anyway. So back to typical designs and implementations. Maybe someone else will be inspired to try to do better, if typical shortcomings are exposed. In my opinion, most of the chipamp designs that we see here are far too simple, for example. Many people see that as a virtue. But I'd probably rather see something like multiple "redundant" paralleled chipamps, for huge excess current-dumping capability (for when your bass driver goes down to way-low "out of spec" impedances, which many or most of them do), all wrapped inside the well-compensated feedback loop of a killer opamp, with the chipamps basically just acting as a power-booster stage. (A Hawksford Error-Correction topology also looks very promising, wrapped around the chipamps, at least in my simulations.) At any rate, with enough paralleled chipamps in a well-designed configuration, any bass driver could be blown into flaming bits in a few milliseconds or so. So I think that any lack of bass that you heard with any particular chipamp designs was simply a shortcoming of those designs, or, their designs were not a good match for your speakers. So we're back to your last statement, again. <smile> Your descriptions did get me thinking that maybe we should just say "screw it" and tri-amp everything, with whatever amp type does each range the best (for the particular type of driver being used) when using the easiest, cheapest most-typical design of its type. They could be made even better, then, probably, too, since they could be optimized for a narrower frequency range. (It's not A.D.D.! It's "Agile Focus"! <grin>) Sorry if I'm not making much sense, tonight. It's been a long, difficult day. Tom |
#42 | |
#43 |
I have owned two amps that I beleive are based on Class D circuitry. I am a noob, so feel free to correct me if I'm wrong. Just say "hey noob, stfu". The first was an Innersound 300 II. The only amplifier that I have experienced with more power was the Krell FPB 400. It also sounded very nice.
I currently own (and love) a Krell 400xi integrated. I use it to drive a pair of B&W 802s. It is not as powerful as some of the other amps I've had, but it packs more punch than you would expect based on its size. I've had this amp for a few years now and have no intention of changing it out. I am currently entertaining building a chip amp to try in my second system. I want to replace a Sansui AU719, which is driving a pair of ADS Sat7s. I do somewhat doubt that the chip amp will outperform my Sansui, especially if the $200 is used to build the chip amp was invested into reconditioning the Sansui. But I am up for trying something new. Does anyone have any thoughts on this? |
#44 | ||||
Class A Class A/B Class D Chip amps Tubes Which one? As always there is no reference and stating the obvious that it will be system and user dependant tells us nothing. A lot of DIY ers from observation and IMHO really don't have a proper playback system for proper evaluation , nor do they have a constant reference , instead choosing to jump from one project to the next . Comments on anything being made here , pre-amp , amp etc , should always be followed by the users setup , if not how can anyone tell or follow along , anyone commenting about a new class D sounds better than my Krell means nothing unless the rest of us can get a reference . Quote:
Must say , the IC150 is a pretty good backup, the flexability and build is astounding , the sound is pretty good , not top tier , but pretty good not bad for an old op-amp .. Quote:
#45 | |
#46 | |
#47 |
Has anyone else tried the wyred 4 sound class D amplifiers ?
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| So many chip amps ? | Buzzy | Chip Amps | 6 | 31st August 2007 08:29 AM |
| Help... Need Chip amps | game_master | Chip Amps | 1 | 9th March 2006 03:14 PM |
| Has anyone compared the Chip amps against Class T amps? | soongsc | Chip Amps | 3 | 24th July 2005 11:50 AM |
| Any Class AB Chip Amps ? | LS | Chip Amps | 1 | 22nd July 2004 08:07 PM |
